Battery charger for lithium battery
For my gt3 rs. Anyone know if I need to use a special charger for this kind of battery? I need to chargenit in between track days and Sunday drives.
battery charger for lithium ion batteries
I use the charger from Porsche Tequipment-plugs into the lighter and works great. I was told that any trickle charger will work but if something goes wrong,I want Porsche on the hook-mucho expensive battery!
Suitable chargers
f
Charge the battery only using a suitable
electronic charger with IU-charging
characteristic. Such chargers can also
be connected to the battery for extended
periods without them causing any damage
to the battery.
We recommend using a Porsche trickle
charger. Your Porsche partner will be pleased
to advise you.
to the battery.
to advise you.
f
It is best to charge the battery using a charging
current of approximately 3 to 5 A.
1. Always observe the instructions of the charger
manufacturer.
Depending on the type of charger, the battery
may have to be disconnected for charging. In
this case, always disconnect the negative lead
first, and then the positive lead – risk of short
circuit!
Reconnect the leads in reverse order.
2. Before charging, cold batteries must be
manufacturer.
circuit!
warmed up to room temperature.
this was copied directly from the battery owners manual.
WheelsupZR1
10-20-2015 08:36 PM
