Tpms
try over-filling the tires by a few lbs with the car on. then after warning clears, simply lower back to normal psi.
i lower my psi for track events all the time. after filling back up to normal psi afterwards, sometimes simply resetting/re-learning isnt enough to clear the warning...but the over-filling method works every time.
I took the car to Porsche of Arlington and they were unable to re-set the TPMS without over-inflating the tires. They have ordered me a new TPMS module and two new tire monitors for the front. They already replaced the rears. Gotta say that they are doing their very best.
Mr. B
OK, today I dropped the car off at the dealership for a new TPMS module, plus two new tire monitors for inside the front rims.
The dealership already installed tire monitors in the rear rims.
This should solve the problem (I hope).
Anyway, it's all covered under the CPO warranty.
Mr. B
IMHO, CPO is the ONLY way to go!!
Mr. B
Problem has returned
Mr. B
Mr. B
Boy, is this ever frustrating!
Mr. B
Seriously considering disabling TPMS. Bought after-market wheels (TechArts) and had local shop put them on with the TPMS. I get Warnings EVERY time I fire up my CS. Yes...I check pressure regularly. Thought it was my aftermarket wheels. I feel better now that I know you are all suffering with me. :') Misery loves company.
How warm is the ambient temperature when you are checking pressures? Baseline for TPMS to properly calibrate is something like 60 degrees F and cold (not driven on) tires. If, for instance, the ambient temp is 80 degrees and if you set pressures per spec (33/39 for my 997 Turbo) TPMS will error out as it "thinks" the pressure should be higher for the given ambient temp. Same thing applies if you are checking in direct sunlight which can cause pressures and TPMS readings to vary side to side.
When I'm at the track, I run 32/35 hot. TPMS error messages abound! When I leave the track, ie tires are still very warm to hot, I fill to 45/50 which resets the error messages, drive 225 miles home, park in the garage and the next morning when temps are 60-ish, make a final adjustment; usually bleeding off 2 or 3 lbs. That procedure works well for me. That said, the TPMS system still is a real pita! Best,
It's summer here--high 80's.
Mr. B
You probably need to add 2-4 lbs more to whatever your baseline pressures are to compensate for the higher ambient temps. That should allow the TPMS system to "think" that pressures are appropriately increasing as the temperature increases. You might also check your owners manual (or any other official Porsche publication you received with your car) as I recall seeing a graph somewhere that plotted temperature vs pressure which will give you an idea of where you need to be to keep the system "happy" under varying conditions. For a computer based system, it really ain't very smart.......
A solution
Does this TPMS saga ever end??
So, the dealership replaced the monitors in the two rears, and everything was fine--for a while. The TPMS read-outs are incorrect but, apparently, Porsche knows that.
I set the pressures using a very accurate gauge and, guess what, the yellow tire indicator has popped back on!!
Mr. B
Mr. B
It's great to have that CPO warranty!!
Mr. B
PLS let me know how that works out for you,
The dealership that did the job for me was Porsche of Arlington in VA.
Mr. B
Mr. B
need4speedmotors
996 Turbo Vendor Classifieds
01-12-2016 05:41 PM
C5tt
10-24-2015 07:35 PM
miken168
10-06-2015 09:21 AM
need4speedmotors
997 Turbo Vendor Classifieds
09-28-2015 04:47 PM
