What are the mechanical differences between GT2 and GT2RS
Does anyone know the actual differences between the two cars? Are the pistons, turbos, exhaust and fuel injection the same and just adjusted differently.
How about the suspension? Is that the same or just different settings etc.
I have an 08 GT2 and am curious about these issues.
-the turbos are different and better - not sure how.
-think the pistons and fuel injection are the same - not for sure
-the suspension is using monoball joints instead of rose joints(eliminates any rubber) so much more stable chasis when turning and hitting any bumps, and improves turn in and feel, does not make ride harsher.
-the clutch is using a lighter fly wheel .
- the intercoolers are much better.
I have ridden in a gt2 rs at the driving school several times around the track with an instructor driving it (one of the times it was Hurley Haywood going all out). It was awesome, but now that I have my 08' gt2 for less then half the cost of a new rs it really did not feel that much better. I have already done a few mods which puts me at similar power ratings as the rs and next I will do a stage 1 suspension for about a little over $1k and will have the same suspension as the rs.
i have tarrett dog bones , toe kit ect, solid bushings and moton 3 way adj. car handles great .the difference is i think is that the hot side of the turbos is from the 997.2 cars . also it boosts 22 psi the gt2 is 20 psi.
I will be having RSS in Costa Mesa, CA do them since its just a drive away from me. But more than that they did my other mods and gave me a tour of their operation, very impressive. I notice that many mod shops that do suspension, use the RSS products.
I feel like a "me too" here - I have a 2008 997 GT 2 as well. My mods are just an EVOMS 600 upgrade. Have any of you guys:
1) Installed an aftermarket exhaust - can you describe what benefits you got, and how loud does it make riding inside ( given how much noise there already is inside), and
2) has anyone done extensive tracking with the PCCB's, his are they surviving and if you've changed to steel rotors and pads, which ones and how do you like 'em? Thanks in advance.
i have tracked pccb prett hard. to the point of the billowing smoke. have about 15 track days on em. no cracks . they are stroong but im gonna swap out rotors for the brembo steel slotted ones.
i had a bbi exhaust no cats and it sounded like a gt3 rs . and saved about 20lbs from stock exhaust.
What I think I know is:
Rear subframe is solidly mounted with aluminum bushings. The rear lower control arms had spherical bearing inner mounts with a soft rubber dust cover and the thrust arm bushings are the same as the front rubber ones.
The rear toe arm inner mounts are spherical with the same style soft rubber dust cover.
From Suncoast Ric, these components are unique to the GT2RS, and are not shared with the GT3RS:
- Front Shock Absorber - 997-343-041-80 x 2
- Front Springs - 997-343-531-80-504
- Rear Wheel Carrier - 997-331-111-80 AND 997-331-112-80
- Rear Track Rod - 997-331-045-80 X 2
- Wishbone / Control Arm - 997-331-041-80 AND 997-331-042-80
- Rear Underbody Strut - 997-331-081-92
- Rear Shock Absorber - 997-333-051-80 x 2
- Rear Springs - 997-333-531-81-504 (possibly other rear shock hardware too)
Not sure how they're different...but the part numbers are not the same for the GT3RS. Here is an interview posted by a member during an exclusive event:
http://www.youtube.com/watch?v=DXHZL...layer_embedded
Andreas Preuninger describes some of the differences in engineering, however, not everything he has stated is 100% true - the rose joint/spherical ends and the remove all the rubber comments are not completely correct.
As far as the body is concerned, the rear deck is the same, as is the wing, although the gurney extension is different. There are a few carbon fiber trim pieces, different bumper, and on the front end, the front fenders are available in optional carbon fiber.
b
The front fenders are steel unless you opt for the $6800 optional carbon fiber fenders which are one piece and donot have the add on fender flare of the steel fenders. i have had both cars a GT2 and a GT 2RS and once you drive a 2RS you won't want to go back to the GT2 which is also a very nice car. Thanks
I have also driven both. The driving differences on the road are not really discernible in the case of a reasonably upgraded GT2. I am sure on the track it is much more likely to become noticeable. When my good friend who I bought my 996 GT2 from, bought his new GT2RS, I asked him what it was like compared to his his old GT2. He shared the same opinion with me. When I pressed him for his impressions on the difference, his initial response was "that car puts it down!" (referring to the old one). No question the GT2RS is an upgraded version, superior in many ways. The GT2 is not obsolete yet though.
bob
