Rev the engine in neutral but won't past 5K
Anyone have this experience?
Mine is 997.2 3.8 GT3 RS. with GMG center cross pipe.
It run fine and strong in all gears. But I just notice this in parking lot:
- When it is in neutral ( engine cold & engine hot ), I try to rev it over 5K just want to hear the exhaust note, but it won't go over 5K
_ I never notice this with OEM center muffler.
did you just have some other problem with that car, I think you had another post not long ago..??? was this your car that has a clutch problem or a starter issue? Or I remember someone with a ECU problem?
my memory is terrible, maybe I am mestaken you for another car
I just found out, if I put it in 1st gear, it will rev. over 5K no problem. But not in netural.
I don't have starter or clutch problem, it was a factory recall.
I don't think that it should be able to rev al the way up in neutral. It's probably a safety feature to save the motor from clueless owners.
Why in the world would you need to rev your motor past 5k in neutral. That's not good for the motor.
He said why. It won't hurt it at all. The car is designed to rev and most people here shift well above 5,000 rpm. There's no beneficial reason to do it, but it won't hurt a thing. Don't do it cold but warmed up, no issue at all.
I would tend to think that a load dampens the internals of an engine. Revving an engine in neutral places no load on the motor, therefore no dampening. I'm not an engineer, but from the old school where we were taught not to make it a practice to rev the engine for the fun of it.There is nothing to gain but engine wear and looking like, well..... whatever.
are you serious?... Load vs. non-load RPMS at/near redline are two completely different animals... If you think its ok or "won't hurt a thing," then go out to your car and free rev it to redline in neutral. You better be hoping your motor was perfectly put together and balanced.... LOL.
