Seat Mount Bolt Size
Old 05-05-2012 | 07:16 PM
Car-Narcissist's Avatar
Car-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond repute
Arrow Message Removed
Message Removed
Old 05-05-2012 | 08:22 PM
NorthVan's Avatar
Get one from the dealer, if you have problems getting them in loosen them all up and tighten them down a little at a time, then switch to the next bolt.
Old 05-08-2012 | 01:15 PM
jurnes's Avatar
jurnes has a reputation beyond reputejurnes has a reputation beyond reputejurnes has a reputation beyond reputejurnes has a reputation beyond reputejurnes has a reputation beyond reputejurnes has a reputation beyond reputejurnes has a reputation beyond reputejurnes has a reputation beyond reputejurnes has a reputation beyond reputejurnes has a reputation beyond reputejurnes has a reputation beyond repute
Threads are NOT SAE. Thats for the seat belt anchors. Sorry for my miss-information
Get the right tap set and clean up the chassis side of the threads, and as stated above get all four bolts started before tightening to 34 ft/lbs.
Porsche specs that new bolts be used for each installation. Sounds like you could use a new set. (cheap from Suncoast)
Old 05-08-2012 | 04:26 PM
jurnes's Avatar
The thread pitch is 1.5, but my tap die set is a small kit and I don't deduce the bolt size. It is bigger than 10mm. The spare seat bolt I have won't thread through the 10mm x 1.50.
Call Ryan @ Suncoast?
Old 05-08-2012 | 04:32 PM
NorthVan's Avatar
Originally Posted by Car-Narcissist
Right. I understand about the tap. The question is... what is the thread size?
Get a new bolt and match it up to the bolt...who knows what kind of misinformation you can get on a forum
BlackMarketRacing
12-03-2015 10:46 AM
The_Ruski_Driver
10-25-2015 08:40 PM
ModBargains
Audi Vendor Classifieds
09-01-2015 05:26 PM
ModBargains
08-20-2015 12:28 PM
pwdrhound
08-20-2015 05:54 AM
Quick Reply: Seat Mount Bolt Size
