Notices
Best engine oil? What are you using?
Old 07-10-2012, 11:12 AM
DD GT3 RD's Avatar
DD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud of
I hear MOTUL and REDLINE are some of the best (I don't know if this is true at all).*
I see top of the line cars like Ferraris and Porsche come with MOBIL1 so that has to mean something? Or just big money and marketing?
Any input? Motul? Redline? Royal Purple? Mobil1? Castrol?
I used to have a GT3 and have a Boss 302 now. Live in LA, CA so no cold weather. So curious to hear what you guys think and are using yourselves.
Old 07-10-2012, 02:01 PM
Chkmgnt59's Avatar
Chkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud of
Mobil 1 is decent, but if you want that extra bit, Motul and Amsoil are the two best. Royal Purple is 100% marketing, I've seen too many guys with problems with their quality. Castrol is on about the same level as Mobil 1 IMO.
Old 07-10-2012, 02:15 PM
snowboarder54's Avatar
snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !
Mobil 1 5-50 race oil! Pricie but good.
Old 07-10-2012, 02:37 PM
Steamboat's Avatar
Steamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond repute
LN Engineering has a great deal of useful information on lubricants on their website. Here are a couple of good references. The first contains info specific to both air cooled and water cooled Porsche engines so just make sure what you're reading applies to your situation.
http://www.lnengineering.com/oil.html
LN Engineering points out that Mobil 1 has been reformulated during the past several years and has been significantly degraded. I am currently using Joe Gibbs Driven GT 40 which was made available earlier this year and has replaced Motul 300V as LN's preferred product.
http://www.lnengineering.com/joegibbsracingoils.htm
Hope this helps.
Old 07-10-2012, 03:04 PM
gu9cci's Avatar
gu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond repute
Motul here
Old 07-10-2012, 08:37 PM
DD GT3 RD's Avatar
where do you buy it! I cant find where to buy motul anywhere
Old 07-10-2012, 08:44 PM
gu9cci's Avatar
ln engieneering
Old 07-10-2012, 08:53 PM
DD GT3 RD's Avatar
Originally Posted by gu9cci
ln engieneering
Is that a website or shop?
Thanks!
Old 07-10-2012, 08:56 PM
gu9cci's Avatar
Old 07-10-2012, 09:31 PM
David9962000's Avatar
David9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond repute
Old 07-10-2012, 10:03 PM
RAudi Driver's Avatar
RAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud of
Stay away from Redline. It's garbage.
Motul is the best. It's been tested over and over again. I use the Motul Xcess 5/40 since day 1 in the RS4 and as soon as I took possession of the Gt3, I switched it out to the Motul.
If you can afford the Motul V300, then go for it, otherwise, the Xcess is the best. Other great oils are the Lubromoly and Pentosin, but the Motul is the best.
Old 07-10-2012, 10:26 PM
SKXF430's Avatar
SKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud of
Mobile 1. It is the recommended oil by the factory.
Old 07-10-2012, 11:25 PM
DD GT3 RD's Avatar
Problem is MOTUL doesnt make a 5w50 which is the recommended for my car
So now im trying to figure out what to do!
I also used MOTUL in my RS4 and I felt a difference!
Old 07-11-2012, 01:51 PM
TurboRacr08's Avatar
TurboRacr08 is infamous around these parts
Mobil 1!
Old 07-12-2012, 08:25 PM
mdrums's Avatar
mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !
DD GT3 RD, Castrol Syntec has 5w50. I used to use it in my 09 Carrera S.
Quick Reply: Best engine oil? What are you using?
