TiKORE Titanium Lugs
TiKORE Titanium Security Bolts
Hey everyone, we are new site sponsors and wanted to introduce ourselves. TiKORE Industries (pronounced Tie-Core) was established in 2010 to serve the needs of the aftermarket automotive industry. TiKORE designs, engineers, and manufactures titanium and other alloy products at its headquarters located in Fort Lauderdale, FL (USA).
We offer titanium lug bolts (security and none security) and titanium lug nuts for all brands of vehicles (custom sets as well for those folks running spacers).
Please note we roll all of our threads, manufacture the bolts in house and all of our titanium bolts are crafted from grade 5 certified titanium bar stock.
Weight savings, titanium is approx. 45% lighter than steel components.
In regards to our Porsche bolts the weight savings are slightly different as Porsche uses an aluminum ball seat, thus lighter weight in that area, but risk of wearing down the seat and oxidization of the aluminum. These bolts offer weight savings and an escape from the weathering that we all see from Porsche lug bolts.
The weight of the factory Porsche set is 4.11 lbs. The weight of the TiKORE set is 3.00 lbs.
TiKORE Engineering note, we made sure the security bolt and the regular bolt weigh the same.
Titanium Facts
Grade 5 6AL-4V Titanium (Tikore's preferred material)
Yield Strength: 128,000psi
Ultimate Tensile Strength: 138,000psi
Shear Strength: 79,800psi
Density: .160 lb/in^3
Black Finish Not Available
We are not offering the black coating. We did a special run awhile back but the vendor we were using for the special coating ended up being difficult to work with. Mind you, for a durable black finish this is a very expensive process and we only want to offer the best to our customers. At this time TiKORE has the bright machined or matte bead blasted titanium finish available.
