Report Coolant fitting failures/repairs
#31
#32
#35
It seems the NHTSA has opened a file for the Coolant fitting failure on the GT3/GT2/Turbo glued in fittings. IF you have had a failure or done a preventative coolant fitting repair please file a complaint. The more we have on file the better the chance action could be taken.
https://www-odi.nhtsa.dot.gov/ivoq/
Thank You
Peter
Thank You
Peter
This and the center-lock issue should be written up as a B-school case study on how to destroy customer loyalty.
#37
#38
Just because you're concerned isn't going to help the DOT/NHTSA make a case against Porsche.
#39
So what, I should wait until it fail and crash then I file a report?
Isn't this similar to the Firestone tires recall? NTSB recalled millions of Firestone tires because the potential risk of burst? How many failures need to happen before they started the recall?
I have seen many recalls where no serious injuries had occurred and the issue didn't seem all that bad. They still issued an recall.
#41
Steve W on rennlist did a DIY with the pinning of the pipes in the car. Look at this thread - it will show you the fittings.
http://forums.rennlist.com/rennforum...n-the-car.html
#43
I spoke to a NHTSA rep and his supervisor. I did not have a failure but was advised by my mechanic that this issue had to be addressed even though I didn't have a leak yet. They told me to file a claim. I recommend calling them.
#44
#45
How did you fill out the form? Did you call instead of submitting the form? What did you report as the "incident"?
