Report Coolant fitting failures/repairs
#121
No need to PM the preventative measures. Please just post some up. I have a feeling there will be many people wanting to know including myself.
#122
nothing secretive.. just check clutch/flywheel while engine is out. Also, good time to upgrade to semi solid engine mounts if you dont have one, check water pump, all the hoses. While at it, why not upgrade to semi solid tranny mount and cup cables. Do it all while it is getting the surgery. =)
#124
My 996GT3 is currently undergoing preventative coolant line welds. While the engine is out, getting water pump replaced, changing out the 9yr old hoses and coolant reservoir, upgrading the tranny mount with 997 version and engine mounts with RSS. I was having trouble shifting from 2nd to 3rd on the track so the transmission is being worked on. Finally, got a set of the Numeric cables to be installed.
#125
#126
FYI guys... while you have your engines our we also discovered another nasty coolant pipe problem that can be addressed.
For GT3s:
http://www.sharkwerks.com/products.php?pid=386
For GT2's and Turbos:
http://sharkwerks.com/products.php?pid=394
For GT3s:
#127
For GT3s:
For GT3s:
Peter
#129
Any updates or did some one file for another extension so 'they' can evaluate a little longer. PAG is probally weighing the ROI on NOT issuing a recall vs the possible damage to the brand. I hope bean counters that caused this went by the wayside like their last CEO.
#130
UPDATE
Just called NHTSA and asked what the status was regarding the coolant leak. Responce was confounding. The gentelman stated, "we currently are not investigating this vehicle, seeing as we only have one (1) complaint regarding coolant loss." I asked what happened to the other 15/20 I know about via this forum. "Sorry sir we only have one complaint" , was his response again.
Can someone verify my results? I called NHSTA. Did I call the wrong agency?
#131
Here is the contact information I received from NHTSA when I filed my complaint of coolant system failure back in May, 2013. At the time, they gave me a claim number and indicated they had received other complaints.
Stephen McHenry
Federal Investigator, US D.O.T.
National Highway Traffic Safety Administration
Office of Defects Investigation
NVS-213 Room W48-308
1200 New Jersey Ave., SE
Washington D.C. 20590-0001
202.366.4883 or 1.877.536.8368 x-64883
Fax 202.366.1767
"Stephen.McHenry@dot.gov" <Stephen.McHenry@dot.gov>
Stephen McHenry
Fax 202.366.1767
#132
UPDATE
for example: http://forums.rennlist.com/rennforum...98-post55.html
#133
You were unprepared for that call....
