NEW AiM SmartyCam HD GPS Racing Camera | M-World
M-World is pleased to introduce the NEW AiM SmartyCam HD GPS racing camera, released at the 25th Performance Racing Industry Show.
SmartyCam HD is a GPS racing camera which overlays data (speed, lap times, G's, track map/position) directly on videos on-the-fly. Absolutely no post-processing needed!
When integrated with a data logger such as the AiM Solo DL, your videos will include information such as gear position, brake pressure, throttle position, etc... just like a F1 racing video!
Preliminary Specs:
720p @ 30fps
Built-in GPS
Built-in data logger
Built-in accelerometers
Full aluminum water-proof construction
Available in bullet cam version - SmartyCam HD GP
Integration ready with AiM data loggers for more data channels
More info:
http://www.m-world.us/aim_smartycam_hd
Preliminary Specs:
720p @ 30fps
Built-in GPS
More info:
I currently have a Smaty Cam \ MXL, is my assumption correct that the Smarty Cam HD is a direct replacement to the Smarty Cam? IOW, simply connect the two cables operating the current Smarty Cam to either of the two HD camera setups and all data will record the same onto the new Smarty Cam HD?
Also, does AIM offer an overlay graphic that appears the same as the MXL dash yet?
Tim
Tim
Tim
Tim
New software will be released along with the HD camera release, so hopefully that will include some new graphic choices as well.
It now records HD videos, has more intuitive controls/LCD screen layout, full-sized SD cards for easier handling, and full aluminum construction.
If I had to, not having HD would be my only gripe with the current SC, looking forward to HD. BTW Richard, is the wide angle lens different in the HD from the current SC and any different between HD vs HD bullet?
From my understanding there will only be one version of lens offered for HD and HD GP. AiM recently made some changes to the lens pack so I don't have the exact horizontal field of view spec, but I would expect it to be similar as before.
I saw something on another forum that indicated the true launch should be September 2013. Sounds like AIM wasn't happy with the performance of the product and has made some improvement over the past months.
RallyBird
10-07-2015 01:20 PM
turbotuner20v
09-11-2015 12:02 PM
