Success with lithium battery replacement?
I've had excellent results using lithium battery in my sport bike. Great way to lose a few pounds!
After searching the forum, some horror stories found on lithium batteries either burning up or going dead (undersized for application).
Any first hand experiences good or bad to share?
Trying to figure out what is the hot ticket.
Thanks in advance
Thanks in advance
Try this guy. He makes a great product at the right price. No affiliation. Just a happy customer.
www.lithiummoto.com
www.lithiummoto.com
I have had great experience with the Voltphreaks also, their V900 model that I run in my turbo. Have not any issues of overheating with it, even after track days. The turbo draws a lot of power under full throttle, when the secondary injectors kick in and my car is modified with about 650 hp, so the fuel pump has been changed and it pulls a lot current. No issues there either.
The Voltphreaks does come with an on/off switch on the battery with an optional external on/off. That is very useful for me as I don't drive the car that much and I can't plug it in. I have left the car for up to a month and the it still starts. The only issue is when it gets cold. In those situations, you should turn the headlights on for 15-20 seconds which actually warms up the battery enough to get it to start the car on the first crank. Else you may have to crank it a couple of times.
I've been running a Lithium Pros L925 in my GT3 for over 2 years now (daily driven) with no problems. Left it parked for 1-2 weeks at a time while I was traveling and it's always fired up on first try upon return. Fits great with the off the shelf Rennline battery kit for the Porsche as well.
Found this on Voltphreaks site:
Lithium batteries could be incompatible with some (not all) Porsche GT cars. We have heard from some customers that their GT's alternator may not maintain the right voltage to charge a lithium battery. We are not aware of any other cars that show this behavior.
Almost all car alternators maintain 14V to 14.6V to properly charge the car's battery, and this is what the Voltphreaks battery expects. Some Porsche GT's undercharge their lead-acid batteries, this is not compatible with the more efficient lithium batteries. Below 13V, a lead-acid battery will be partially charged, but a lithium battery will be barely charged. If purchasing a Voltphreaks battery for a Porsche GT2 or GT3 (or if you suspect your car's voltage may be incompatible), measure the voltage with engine on (so alternator is supplying power) first to insure compatibility. Voltage at idle should be around 14-14.6V. This likely only applies to Porsche GT's, as we have not encountered this issue with other cars including other Porsches.
Need to measure what voltage my alternator is putting out.
Looks like the main players are:
OEM
Braille
Lithiummoto
Lithiumpro
Voltphreaks
Anyone got feedback good or bad on these? Price varies wildly especially as it looks like all the cells come from China.
Cheers
Jay
OEM
Braille
Lithiummoto
Lithiumpro
Voltphreaks
Cheers
Jay
Call the guy at Lithiummoto and get some expert advice. He is a small business person and can give you the straight story on how all these are basically the same the only difference is price. aka markup and the size of the hole in your wallet. He knows each of the brands to some extent and can talk about their features. He does this stuff for a living and knows about the science.
Additional info on the Voltphreaks. I just went out to look in my GT3. The remote wouldn't unlock the door. I opened it by putting the key in the door. No lights came on so the battery is dead. That's when I noticed that I had left my Dual external GPS plugged in to the 12V power point for over a week without starting the car.
I pushed the button to turn the Voltphreaks battery back on. Car started up instantly as if I had run it two hrs ago.
The battery's shutoff/reserve power feature worked perfectly. Pretty cool stuff.
