CGT approach angle and overhang
Originally posted by 20C4S
Ray,
when u mean scrape, is it the front or the carbon under tray?
Ray,
The plastic front lip is pretty sturdy. It's not as soft as the plastic chin lips on the 911. I go very slow and scrape it all the time pulling into the garage nose first, and it doesn't look any worse for the wear. Recently, I started backing in, and there is only a whiff of scraping.
What it needs is a system to lift the car via a dash button when you need to overcome a driveway. I believe the Lamborghini Diablo had that several years ago. That would be the best solution.
Originally posted by Gramicci101
Would 1 cm really make that much of a difference?
This is my driveway...
I have indicated in the pic, where I scrape on my driveway. It doesn't even look that high or steep, but yup, I scrape. I'm scraping the carbon undertray...right about the middle of the car. The chassis is too long. Time to modify the driveway! <SIGH>
Cheers,
-Nick
Cheers,
-Nick
Re: This is my driveway...
Cheers,
-Nick
Cheers,
-Nick
Did the dealer hold you to MSRP?
Cheers,
-Nick
Cheers,
-Nick
Re: Re: This is my driveway...
Originally posted by nberry
Hey Nick I thought you were getting yours in NOV. 2005. They move up the production date because of the airbag issue?
Rgds,
-Nick
Originally posted by deanger
Thanks -- I did read the early posts but couldn't tell if anyone ever came to a conclusion about porsche's numbers. My house has a driveway from h$ll. My guess is I'm right around 10 degrees when I come at it from nearly 45-60 degrees! Straight on --- almost all cars scrape.
Don't think that hasn't crossed my mind. It might be time to start an organization -- "sportscaraholics anonymous"
Grant me the courage to accept there are cars I cannot have, the serenity to live with the ones I can, and the wisdom to know the difference.
On a serious note (and I hope changing the serenity prayer didnt offend anyone) WHO should I talk to about my driveway -- an engineer? an architect? I know this will invlove re-sloping the entire 25 foot long inclined portion from the street. I think I need it to end up looking like a ski jump, whereas now it looks like pretty much like a straight line that gets steeper at the bottom. (clearly, the last owner was a Jeep fan)
