GT3 Race Care Help
Old 01-22-2014 | 10:45 PM
SpeedYellowGT3's Avatar
SpeedYellowGT3 is infamous around these parts
GT3 Race Care Help
I am starting to turn my 2004 GT3 from less of a street car and wanting to move to more of a race car but I don't know where to start. I'm wanting to put in about $10-15k to start with but would like some help from you all on what to do? I have already done KW Coilovers, Carbon Fiber seats, cage, six pt harness. With that being said, where to go next?
Old 01-22-2014 | 11:34 PM
SKXF430's Avatar
SKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud of
Do you want to go racing? Or, just HPDE events?
If you want to go racing, you will be better off selling your car and buying a Cup car, Spec Boxster or Spec Cayman. You will save yourself a lot of time, money and headaches.
Look over on the Rennlist and Renntrack forums as many others have already been down that path many times.
Good luck with your choice.
Old 01-22-2014 | 11:49 PM
I am just going to be doing HPDEs.
Old 01-22-2014 | 11:53 PM
SKXF430's Avatar
You have done quite a bit for just HPDE days.
How about brake pads and fluid? What kind of tires are your running?
Maybe, invest in some private coaching which will pay bigger dividends than any additional mods on your car.
Old 01-23-2014 | 01:24 PM
paver's Avatar
paver has much to be proud ofpaver has much to be proud ofpaver has much to be proud ofpaver has much to be proud ofpaver has much to be proud ofpaver has much to be proud ofpaver has much to be proud ofpaver has much to be proud of
you probably want to check into welding the coolant fittings if you haven't already done so. I don't have a 996 3 but I read all the time on the forums that welding those is a must
Old 02-06-2014 | 02:36 PM
rbahr's Avatar
rbahr is infamous around these parts
If you have the normal stuff under control - brakes, tires, belts, seats, etc, you may want to check out my build thread at rennlist: http://forums.rennlist.com/rennforum...n-der-gt3.html
My application is also a good DE car...
Ray
Old 02-10-2014 | 08:18 PM
gt3forever's Avatar
gt3forever is infamous around these parts
you might want to start with some high performance tires...
you know GT3s are light and fast enough no modifications are necessary
Old 02-11-2014 | 11:19 AM
sin911's Avatar
sin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond repute
Light weight wheels with sticky tires, LSD rebuild, monoball suspension components, light weight flywheel conversion, exhaust... It's totally up to you
Sales@RSW
09-03-2015 09:34 AM
Money2536
09-01-2015 04:56 AM
orbelo
08-30-2015 12:26 PM
JMon
08-21-2015 08:20 AM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-18-2015 03:42 PM
Quick Reply: GT3 Race Care Help
