wheel offset question
I was wondering if the following wheel offset is okay with a 2007 997.1 GT3.
24 Bolt Pattern
Front 18" x 10.5" - Inner Rim Half-6" / Outer Rim Half-4.5" 5.5" Backspace
Rears 18" x 12.5" - Inner Rim Half-7.5" Outer Rim Half-5" 7" Backspace
Anyone knows its availability?
24 Bolt Pattern
Very different specs than most run (9" ET 48-51mm front, typically 1" outer and 8"inner; 12" ET 58-63mm rear, typically 2" outer and 10" inner).
Based on recent experience on a 997.2 which should be identical, I believe you would have big issues with the width if the fronts, and likely also with the offsets on both front and rear.
Very different specs than most run (9" ET 48-51mm front, typically 1" outer and 8"inner; 12" ET 58-63mm rear, typically 2" outer and 10" inner). Based on recent experience on a 997.2 which should be identical, I believe you would have big issues with the width if the fronts, and likely also with the offsets on both front and rear.
PelicanParts.com
930 Turbo Vendor Classifieds
08-18-2015 04:01 PM
PelicanParts.com
08-18-2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-18-2015 03:42 PM
