TPC Racing 997 GT3/GT2 Rear Top Mount Kit
Old 03-03-2015 | 08:45 AM
Harris@TPCRacing's Avatar
Harris@TPCRacing has a brilliant futureHarris@TPCRacing has a brilliant futureHarris@TPCRacing has a brilliant futureHarris@TPCRacing has a brilliant futureHarris@TPCRacing has a brilliant futureHarris@TPCRacing has a brilliant futureHarris@TPCRacing has a brilliant futureHarris@TPCRacing has a brilliant futureHarris@TPCRacing has a brilliant futureHarris@TPCRacing has a brilliant futureHarris@TPCRacing has a brilliant future
Introducing the TPC Racing GT3/2 Rear Top Mount Kit. The purpose of this kit is to replace the OEM PASM-type rear rubber-suspended upper mounts with spherical bearing top plates that allow for articulation and allow for spring conversion to 60mm ID linear-rate springs. The articulation features eliminates "bending" action of the spring as the suspension travels. As a result it will reduce unwanted load at the shocks and reduce stiction, therefor the damping function of the shocks is undiluted by unwanted force. All the factory race car(Cup/R/RSR) have articulating rear top plates.
This kit is compatible with OEM PASM-type suspension and aftermarket Damtronic variant.
TPC Racing GT3/2 Rear Top Mount Kit includes:
Pair of billet aluminum top plates with European motorsport quality spherical bearing, with bearing offset to optimize shock stroke(travel).
Pair of billet aluminum spring hats for 60mm ID springs* ** Machined in USA.
Pair of stainless steel upper bushing nuts threaded for PASM-type shocks. Machined in USA.
Pair of stainless steel lower bushings. Shallow depth to allow for increased thread grip of the upper bushing nut. Machined in USA.
We have machined a limited number of the kits. They are available now. Please send inquires to: info@tpcracing.com or call us at 410-799-7223
Be sure to use discount code 6S0315 for the 6Speed member discount!
* Spring hats are available for other ID sizes springs(2.25", 2.50", 70mm).
** 60mm ID springs are available. Sold separately.
*** Will work on 997TT with Damptronic Coilover shocks.
Old 03-03-2015 | 09:29 AM
White Rock's Avatar
White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !
997.2 Turbo with damptronics?
Old 03-03-2015 | 09:47 AM
This will work on the 997TT with Damptronic Coilover shocks.
Old 03-06-2015 | 08:22 PM
TJ Elliott's Avatar
TJ Elliott has a spectacular aura aboutTJ Elliott has a spectacular aura about
Crap, where was this when I was installing my Damptronics! I purchased monoball top mounts for the rear and couldn't get them to work because I didn't have the custom nut/hat combo. Another innovative solution from TPC, well done!
COBB Tuning
01-29-2022 09:42 AM
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
08-21-2015 06:34 AM
TrackOne
08-20-2015 12:56 PM
Quick Reply: TPC Racing 997 GT3/GT2 Rear Top Mount Kit
