Coolant fitting failure issue
This was actually investigated by the National Highway Traffic Safety Administrations it seems. In the final report (link below) it states the following:
"In response to ODI’s Information Request letter, Porsche identified a manufacturing quality issue with the supplier’s application of adhesive to coolant pipe fittings that resulted in elevated failure rates in approximately 6,800 early production 997 generation vehicles (MY 2007 and early MY 2008)."
So, YES...Porsche themselves admits sh!tty adhesive process. It states that by the 4th week of January the process was automated to ensure proper application of the adhesive. So if you have a March 2008 or later build date then you are supposedly in the "clear"
Water Neck part# 997.106.039.72 and 997.106.039.90 are most prone to failure. Apparently due to seeing highest temps of any of the coolant fittings.
Even though closed...people should REPORT these failures to NHTSA. Especially if in later production 08 and 2009 vehicles (since they claimed it was fixed) especially if driver control of vehicle was lost on public roads. If you were on a track, it doesn't apply.
Letter Sent to Porsche Cars NA:
http://www-odi.nhtsa.dot.gov/acms/cs...3009-56309.pdf
Porsche's response:
http://www-odi.nhtsa.dot.gov/acms/cs...009-57948P.pdf
*section 14a -->they basically threw tracked and modified cars under the bus*
*section 16 --> Porsche's explanation as to why you wont lose control if bond fails while driving*
Porsche's supporting attachments:
http://www-odi.nhtsa.dot.gov/acms/cs...009-57950P.PDF
NHTSA Final Decision:
http://www-odi.nhtsa.dot.gov/acms/cs...13009-5428.PDF
I want to thank my govt for making all this information public.
I hope this helps the community understand who is most at risk etc.
Porsche's response:
