Harness suggestions for Gt3 seat
I just purchased a euro black gt3 seat for the track. Would like to know any harness suggestions. Im not sure what point to have. 4pt, 5pt, or 6pt? i have the techart rollbar if that matters at all.
Any help or suggestions would be great! Thanks
I'm not trying to thread jack. You'll need to know this info too
I have six point racing harnesses and I would like to find out how the anti-subs attach to the GT3 seats. Anyone out there know?
there is a factory bracket that attaches under the seat and provides mounting for the sub belt...Carnewal has the factory piece for $60 US or Brey-Krause has one too but don't know what it looks like or how much.
yea, im solo.
sooooo...... what do you guys recommend for a harness then? i take it a 6pt is the most common? :dunno:
5 or 6 points with cam lock.
Schroth makes some nice ones.
Originally Posted by fortyounce
Could you tell me how the subs attach to this bracket? Are there eye-bolts or something?
I've got the 6-pt Schroth, the B-K sub bar and GT3 seat. Great combination. Easy to install & remove the harness (you need nimble fingers, though, as it wraps around the bar a few times). It's easy after you've done it once or twice, which I do before & after each track day.
You'll also need some B-K hardware to attach the harness lap belts to the car (R-9003 & R-9004). http://www.bkauto.com/porsche/seatmounts.php
k... im looking at gettting the 6-pt schroth in black from here:
http://www.northstarmotorsports.com/...4/productID/58
is there anyother sites that you guys recommend for better prices.
Also, do i want pull down, pull up, clip in, or bolt in?!?!
Thanks for that link Holger... do you need all that hardware?
The lap belts I have clip on (I bought them used, so I don't know if there are different varieties). Here's a photo of the B-K part I ordered for the inside, as you can see it's too long (you need the short one to use the slot in the seat.
I recently ordered shoulder pads for my harness from these guys (probably not a bad idea from a comfort & safety standpoint):
http://www.on-trackperformance.com/s...ness_index.htm
(I paid $37 last week, now they're on the site @ $55...talk about inflation!)
the sub belt has an adjustable loop on the end that attatches to the sub belt bracket..you slide the sub belt loop over the bracket before you bolt it to the seat...once the bracket is attached to the seat it is a simple matter to reach through the opening in the seat bottom to grab the sub belt when needed or to put it under the seat when not in use....
Thanks a lot fellas!
