GT2/3 Sways!!
Old 04-09-2006 | 02:02 AM
iLLM3's Avatar
GT2/3 Sways!!
What's up guys, im looking for GT3 or GT2 swaybars if anyone has to sell, and maybe whether some aftermarket sways would be better? They are hard to find, i know some of you guys have upgraded
Martin
Old 04-09-2006 | 03:50 AM
02barebones996's Avatar
02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute
im using eibachs
Old 04-09-2006 | 08:07 AM
Doctor K's Avatar
Doctor K is infamous around these parts
barebones,
Do you see any substantial difference with the Eibachs.
TIA
Old 04-09-2006 | 11:00 AM
supercup's Avatar
supercup is infamous around these parts
I have a set of 996 GT3 adj. sway bars, were on my turbo for about 1,000 miles. Send me a pm if interested. I paid $850, make me an offer. I am in Southern California.
JCM
Old 04-12-2006 | 08:51 AM
Turbo Ron's Avatar
Turbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to all
I am using eibachs also.
Old 04-12-2006 | 09:43 AM
paneraiwatches's Avatar
paneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to behold
I will be switching to Eibachs soon.
Old 04-12-2006 | 10:42 AM
iLLM3's Avatar
Eibach's seem to be used by the majority of people, hmm i was told to run GT3's though! Are you guys running strut tower bars, are they even that noticeable on this car?
Old 04-14-2006 | 12:28 AM
GT3Dave's Avatar
GT3Dave is infamous around these parts
Th3 GT2/GT# stabilizer bars and bushings are fine but you won't be able to use either the stock 996TT drop links or the GT2/GT3 drop links. You'll need new drop links. BTW the stock GT3 sway bars are cheap (same as the 996 GT3 Cup), the drop links are expensive in any case and don't work. We're working on replacements that do work and are adjustable so if you're running coil-vers you can remeove any preload after corner weight setting.
Old 04-14-2006 | 01:22 AM
iLLM3's Avatar
Hmm interesting.. There are several companies that have Endlinks out, i was checking out vividracing.com and they have 2 options that work with the GT3 sways and are recommended along witht he H+R's. You would recommend GT3 sways over H+R?
Old 04-14-2006 | 01:39 PM
GT3Dave's Avatar
I prefer the GT3 swaybars because they are tubular (lighter and offer plenty of stiffness).
You can only use drop links designed to work with a GT3 sway bar on a road car (one that doesn't have the swaybar attachment on the threaded coilover strut mounting) so the top end is a long bolt that goes through the rod end and then the upright (clamp to strut). Otherwise the lengths (and attachment method) are wrong.
The front GT3 swaybar will never be run stiffer than the middle position because thereafter that you begin to bend the front tub. So unless you are going to install a full cage with tubes to all the suspension pickup points and subframe mounting points this is all you need.
The rear sway bar is essentially the same issue. A longer link than the GT3 and the top end is a long bolt going through the rear upright clamp on the strut.
I'm waiting for some prototypes to test, but if you have access to a machine shop and rod ends you can make exactly what you want.
Old 04-14-2006 | 01:44 PM
GT3Dave's Avatar
Let me correct that the links you need are shorter (not longer) and have a different attachement on the top.
Rguy
04-12-2020 11:11 PM
Myclue
17
05-19-2016 11:14 AM
cherplex
10-01-2015 08:30 PM
bongnation
09-25-2015 02:58 PM
jpik2003
09-10-2015 05:18 PM
Quick Reply: GT2/3 Sways!!
