Hairline cracks in PCCB rotor
The v2 PCCB brake rotors have 400,000 carbon fiber bundles. Which has been increased from 3,000. This leads to much more longer life. A new lost core forming process aids in production which will ultimately lower costs for replacement.The rotors with their new arcus internal design allow less frictional air movement internally. So that at 200km/hr more 250 litres of air per second. This is a 20% increase in efficiency over the old PCCB's
. So:
TAKE A GT3 WITH 381BHP
takes only 14.3 secs to go from 0-200km/h(124mph). The new PCCB v.2 only takes 5.4 secs to DECELERATE form 125mph to zero! That equates to max brake performance of 1,200 HP!
. So:
Are the new PCCB v.2's direct replacement of the orig. PCCB's on the car? If so, then the question is how soon will the price come down? Do you guys think the price on a set would come down to less than $5000 any time soon?
i will post some pics later
thanks
stopping distance (or time) is determined by the tires.
How many miles on the rotors? its not unusual... it probably came that way and you never noticed it, a lot of the gen 1 rotors came out of the box looking like that, it really isnt a problem, even between the holes like that, these arent cast iron rotors, I would worry more about flaking then those cracks in your pictures, It is only on the surface they dont run through the rotor, still a good idea to have the dealer look at it though, cant be absolutely certain just from a picture,(like trying to diagnose a car over the phone lol) if the rotor was bad and the cracks went all the way through it most likely would of already failed.
Here is porsche's exact wording on those cracks for pccb,
Cracks (tension release texture) in the brake disc friction surfaces
Cracks in brake disc friction surfaces have different implications than for grey cast iron brake discs.
Cracks are not a wear criterion for PCCB brake discs but are already present in new condition (depending on production).
- Due to the different material composition of the friction layer and rotor body, the friction surfaces (even in new condition) are covered with a non-critical crack pattern (tension release texture). Individual tension release cracks partially course along the perforation bores.
- The tension release texture is produced during production starting at the brake disc surface and does not represent a safety risk. There is also no danger of the friction layers chipping from the rotor body, as the friction layers have nearly no residual stress due to the tension release texture.
- The tension release texture is clearly visible in new condition and can differ considerably between the retainer side and opposite retainer side of the brake disc.
yes there is...and it is better to break in new rotors with used pads (or new pads with used rotors) if possible...follow the manufacturers recommendations for the pads you are using...if they are stock Pccb pads I believe several moderate decels from 70 to 30, allowing the brakes to cool between each decel and then a couple more agressive decels from 90-100 mph to 50mph allowing cooling between decels will bed them properly...you should do a search on bedding pccb pads or ask for Porsche's recommendations for gen II rotors to make sure as the procedure when rotor and pad are new may be different
Chuck,thanks.Can't find anything on PCCB.I was hoping someone with GT2 or CGT might have direct experience.Porsche Centre says they always put new pads and new rotors on together and do the braking sequence you mentioned.I could put the new pads on the existing Gen 1 rotors but they are partially delaminated and might chew them up more than required.In turn these pads may be too rough for the new rotors.They cost too much to do it wrong!
given your situation I wouldn't put the new pads on your chewed up rotors and if they have transferred material to the pads I wouldn't put the old pads on your new rotors either...no one ever said don't put new pads with new rotors, it is just more desireable (easier break-in) if one or the other isn't new...just drive it easy at first...a few mild stops to set everything and then follow the procedure they gave you...good luck...you will like the gen II's
thanks
