Notices
Hairline cracks in PCCB rotor
Old 05-25-2006, 12:55 PM
bli8's Avatar
bli8 is infamous around these partsbli8 is infamous around these parts
Is it normal to have hairline cracks of no more than 1 mm long on the PCCB rotors? I see not just one, but many of these cracks on my rear rotors. The front ones have no cracks.
Old 05-26-2006, 07:55 PM
bli8's Avatar
Since I didn't get any replies after 96 views, let me re-phrase the question. If you have PCCB's, it may not be a bad idea for you to check your rotors carefully, report back if you see any hairline cracks.
Old 05-26-2006, 08:34 PM
20C4S's Avatar
Bruce,
are they connected from hole to hole?
Old 05-26-2006, 08:38 PM
GT3 Chuck's Avatar
Administrator
you probably haven't received any responses because this has been beaten to death many times...(no search function doesn't help) small hairline cracks from the holes are common...caution is called for when the cracks join between holes...if you are concerned have your dealer or a Porsche tech look at them...not worth trusting your life to some dumbass on a forum...
edit: I hadn't seen your post Arling...the dumbass I was referring to was myself
Old 05-26-2006, 08:56 PM
vincentdds's Avatar
vincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond repute
Bruce
I recently had my PCCB rotors replaced after seeing two local guys fractured theirs at the track. IMO the Gen1 are not all that great. If you do a search over RL there are lots on that topics
PCCB
Old 05-26-2006, 10:49 PM
djantlive's Avatar
search is working! use advance search instead of quick search.
https://www.6speedonline.com/forums/...earchid=123556
Old 05-27-2006, 01:13 AM
bli8's Avatar
Here're a couple of close-up's. What do you guys think? What's strange is that only the right rear has cracks, the fronts and other rear rotor don't have any.
Old 05-27-2006, 01:37 AM
20C4S's Avatar
looks like surface crack but really hard to judge in the pics.
Old 05-27-2006, 01:41 AM
dcl's Avatar
dcl
dcl is offline
dcl is infamous around these parts
Odd that the cracks occur in the rears when the fronts usually take more stress?
Old 05-27-2006, 02:20 AM
NJ-GT's Avatar
NJ-GT has much to be proud ofNJ-GT has much to be proud ofNJ-GT has much to be proud ofNJ-GT has much to be proud ofNJ-GT has much to be proud ofNJ-GT has much to be proud ofNJ-GT has much to be proud ofNJ-GT has much to be proud ofNJ-GT has much to be proud ofNJ-GT has much to be proud of
that's a deffective rotor
Old 05-27-2006, 10:43 AM
empunker's Avatar
empunker is a glorious beacon of lightempunker is a glorious beacon of lightempunker is a glorious beacon of lightempunker is a glorious beacon of lightempunker is a glorious beacon of light
have your dealer check it out
Old 05-27-2006, 12:08 PM
oak's Avatar
oak
oak is offline
not good.....
Old 05-31-2006, 01:09 PM
Mafia's Avatar
Mafia is infamous around these parts
How do the PCCB crack compared to steel rotors? Do they crack normally - like you can still drive on the rotor w/ a bit of a vibration or do they crack in a more catastrophic way?
Old 09-02-2006, 03:50 PM
ze_shark's Avatar
ze_shark is just really niceze_shark is just really niceze_shark is just really niceze_shark is just really niceze_shark is just really nice
Are PCCB calipers compatible with OEM steel rotors/pads ?
I am in the market for a 996TT w/ x50 or a Turbo-S should an opportunity arise, but am wondering whether I should factor PCCB as a reason not to take a Turbo-S.
Old 09-06-2006, 12:00 AM
Moogle's Avatar
Moogle is infamous around these parts
they are connecting 3 holes, you need a new rotor.
Quick Reply: Hairline cracks in PCCB rotor
