GT3 RS Part Numbers
GT3 RS Part Numbers
Where could I find a list of GT3 RS Part numbers?
I am looking for the items specifically different from the regular GT3.
Any help would be greatly appreciated! Thanks!
I have some of the numbers for the alcantra interior trims, Thanks to Loren from Renntech.org
GT3RS Steering Wheel -- 996.347.804.90 (red stritching) or 996.347.804.91 (blue stritching)
Alcantra shifter -- 996.424.075.91 (red stritching) or 996.424.075.92 (blue stritching)
Alcantra e-brake -- 996.424.031.92 (red stritching) or 996.424.031.93 (blue stritching)
All these parts are special order from Germany.
GT-3 RS Parts list
From our friends from across the Pond. See Rennlist - GT-2/GT-3 Forum; "Don't sell your car to Thusly"
996-101-901-95 (1) crankcase
996-102-017-95 (1) pulley
964-102-239-31 (1) flywheel
964-114-143-31 (1) starter ring gear
996-104-002-96 (2) cylinder head
996-341-117-92 (1) brake cooling spoiler (L)
996-341-118-92 (1) brake cooling spoiler (R)
996-341-157-92 (1) wheel carrier (L)
996-341-158-92 (1) wheel carrier (R)
996-341-321-71 (1) support for ABS cable speed sensor (L)
996-341-322-71 (1) support for ABS cable speed sensor (R)
996-606-235-91 (1) heat protection for speed sensor (L)
996-606-236-91 (1) heat protection for speed sensor (R)
996-341-661-90 (2) cover
999-217-042-09 (12) hex-head bolt M8 x 35
996-343-041-97 (2) shock absorber
996-343-531-97-504 (1) coil spring set
996-343-070-93 (2) swaybar droplink
996-347-804-90 (1) steering wheel (red)
996-347-804-91 (1) steering wheel (blue)
996-331-111-90 (1) rear wheel carrier (L)
996-331-112-90 (1) rear wheel carrier (R)
996-341-121-90 (1) control arm (L)
996-341-122-90 (1) control arm (R)
900-076-025-02 (2) hex nut M8
999-025-269-02 (2) washer 8.5 x 17 x 6
996-341-441-90 (2) bearing flange control arm
996-331-551-90 (1) support
996-331-051-92 (1) rear axle side section bracket (L)
996-331-052-92 (1) rear axle side section bracket (R)
996-333-051-97 (2) shock absorber
996-362-136-08 (2) front wheel 8.5 x 18 (RED)
996-362-136-09 (2) front wheel 8.5 x 18 (BLUE)
996-362-142-08 (2) rear wheel 11 x 18 (RED)
996-362-142-09 (2) rear wheel 11 x 18 (BLUE)
996-361-303-92 (4) hub cap (RED)
996-361-303-94 (4) hub cap (BLUE)
996-351-801-90 (1) rotor protective plate upper (L)
996-351-813-90 (1) rotor protective plate lower (L)
996-351-815-90 (1) air baffle (L)
996-351-802-90 (1) rotor protective plate upper (R)
996-351-814-90 (1) rotor protective plate lower (R)
996-351-816-90 (1) air baffle (R)
996-352-801-90 (1) rotor protective plate upper (L)
996-352-813-90 (1) rotor protective plate lower (L)
996-352-802-90 (1) rotor protective plate upper (R)
996-352-814-90 (1) rotor protective plate lower (R)
996-355-503-91 (1) rear brake line support (L) ------
996-355-503-90 (1) rear brake line support (L) (PCCB-M450)
996-355-504-91 (1) rear brake line support (R) ------
996-355-504-90 (1) rear brake line support (R) (PCCB-M450)
996-424-075-91 (1) gearshift **** (RED)
996-424-075-92 (1) gearshift **** (BLUE)
996-424-031-92 (1) parking brake lever (RED)
996-424-031-93 (1) parking brake lever (BLUE)
996-424-032-92 (1) parking brake lever ZIERNAHT (RED) (right-hand-drive?)
996-424-032-93 (1) parking brake lever ZIERNAHT (BLUE) (right-hand-drive?)
996-545-111-92 (1) rear window
996-545-521-03 (1) sealing frame
996-545-545-01 (1) trim frame
996-555-121-00-ESY (1) door trim panel (L)
996-555-122-00-ESY (1) door trim panel (R)
996-552-109-00-A12 (1) dashboard trim
996-731-619-30 (1) door mirror housing (L)
996-731-620-30 (1) door mirror housing (R)
996-559-237-92 (1) logo "GT3 RS" (BLUE)
996-559-237-93 (1) logo "GT3 RS" (RED)
996-559-331-90 (1) decorative film front (L)(RED)
996-559-332-90 (1) decorative film front (R)(RED)
996-559-331-91 (1) decorative film front (L)(BLUE)
996-559-332-91 (1) decorative film front (R)(BLUE)
996-559-333-90 (1) decorative film lateral (L)(RED)
996-559-334-90 (1) decorative film lateral (R)(RED)
996-559-333-91 (1) decorative film lateral (L)(BLUE)
996-559-334-91 (1) decorative film lateral (R)(BLUE)
996-559-335-90 (1) decorative film rear (L)(RED)
996-559-336-90 (1) decorative film rear (R)(RED)
996-559-335-91 (1) decorative film rear (L)(BLUE)
996-559-336-91 (1) decorative film rear (R)(BLUE)
996-580-982-02 (1) rollcage
999-170-129-90 (6) spark plug Y5DDC
996-505-980-92-900 (1) front bumper lining
996-511-011-91-G2X (1) front hood
996-511-551-91 (2) gas-filled strut
996-512-991-94-900 (1) rear cover
996-512-959-94 (1) rear spoiler
996-512-983-94 (1) plate (L)
996-512-984-94 (1) plate (R)
999-073-334-00 (6) round head screw M6 x 16
996-803-033-91 (1) seat belt (L)(BLUE)
Chris Green@USP
997 Turbo Vendor Classifieds
01-28-2016 02:22 PM
tropicatango
12-04-2015 02:45 PM
tropicatango
10-14-2015 11:32 PM
carwash
09-26-2015 03:11 PM
Chris Green@USP
996 Turbo Vendor Classifieds
08-20-2015 11:30 AM
