Adjusting geometry on a 996 GT3
Old 08-19-2006 | 09:58 PM
Monodose's Avatar
Monodose is infamous around these parts
How or where from can i get the info i need to learn about how to adjust and what to adjust when it come to tracking my GT3? yes i'm new to this, I've tracked my M but not the GT3 yet, how can i know what needs to be done
What helps to decrease understeer and what needs to be done to avoid oversteer
I need track tips
(everyone else can benefit from the experienced ones also )
Thanks in Advance
Old 08-20-2006 | 01:42 AM
Brandon's Avatar
Brandon is infamous around these parts
I think its going to depend on your driving style and what track you are setting it up for
Old 08-20-2006 | 02:42 AM
zona's Avatar
zona is infamous around these partszona is infamous around these parts
Not sure I would do anything until I have had a few tracking sessions in the car. I would check the obvious things like proper tire pressure, proper tires for the track, brake pad condition, brake system- when was the last time you bleed the brakes of changed the fluid? Maybe a good harness and seat, but that's about it. Oh yeah.............gas! I think you will be very suprised how good a package Porsche put together right off the showroom floor!
-z
I need track tips
Thanks in Advance
Old 08-20-2006 | 03:13 AM
D-UberCars's Avatar
D-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud of
I would highly recommend taking your new GT3 to a knowledgable alignment shop who knows how to set up 911's before you attempt to track. Will make a big difference. From the factory, they are usually not set up quite right. The GT3 is very sensitive to alignment (or mis-alignment). Could cost you more if spin your ride into something solid should you not align first....
Old 08-20-2006 | 05:18 AM
Hamann7's Avatar
Porsche Fiend
Hamann7 is infamous around these partsHamann7 is infamous around these parts
You are absolutely right... almost every GT3 I know of comes misaligned from the factory. It is indeed alignment sensitive, and with the eccentrics in the suspension, it is very easy to lose your alignment as well if you go over bumps or rough surfaces (particularly toe settings).
The GT3 is one of the best or worst handling cars depending on how it's setup.
Old 08-22-2006 | 01:25 PM
gmoney's Avatar
Maybe time to post a sticky of recommended alignment shops?
West End Alignment - Gardena, CA is fantastic w/ many years of P car experience. Done with you in the car, a few test drives etc. and your out the door in 3 hours. He's meticulous.
Old 08-22-2006 | 03:51 PM
Holger B's Avatar
Holger B is infamous around these parts
I need track tips
Thanks in Advance
Street tires or r-compound?
orbelo
08-30-2015 01:26 PM
Sales@RSW
BMW //M
08-26-2015 07:41 AM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-25-2015 04:27 PM
PelicanParts.com
996 Vendor Classifieds
08-18-2015 04:45 PM
PelicanParts.com
08-18-2015 04:42 PM
