wow -gt3 rsr
wow -gt3 rsr
My lord.
I wonder if it's posssible to upgrade the stock gt3 & rs to this beast.
485 hp, 435 nm Torque. yummm
- flat six-cylinder boxer engine, water-cooled
- 3,795 cc, stroke 76.4 mm, bore 102.7 mm Ø
- max. torque: 435 Nm at 7,250 rpm
- max. power: 358 kW (485 bhp) at 8,400 rpm with 2 x 30.3 mm restrictors
- max. rpm: 9,000 rpm
- four-valve cylinder heads
- oil-water heat exchanger
- dry-sump lubrication system with engine mounted dry-sump tank made from carbon fiber
- oil and cooling water refilling system
- intake manifold made of carbon fiber with dual air restrictors and single throttle per cylinder, dual restrictor
- electronic engine management system BOSCH MS 4.0
- required fuel quality: 98 octane ROZ, unleaded
- race exhaust: multiple pipe manifold, open exhaust, no catalytic converter
Originally Posted by kfitz911
I was thinking the same thing about the restrictors - just what kind of power could be had?
find a gt3 with a blown motor...put that motor in, put some kind of muffler on it to make it a little more bearable...and voila..with enough money and patience...street legal GT3RSR..anything is possible
Originally Posted by Origyns 973
...alot...
Actually I'd guesstimate around maybe $40k-$50k?
more than you can afford pal! it's a PORSCHAAAAAAAAAAAAAAAAAAH
*fast and furious picture goes here*
