Rear main seal
Originally Posted by Mussel Kar
My RS seems to be dripping some oil from the rear main seal. Maybe a teaspoon on the garage floor after every drive. Will this go away or am I in for a huge warranty issue?
**** not on this engine also...thought that was never an issue on the 964 blocks (TT and GT2/3) was only the 996 engines...keep me up to date....
Some 996 GT3's have this issue...including mine. My first one would drip a few drops after owning the car for a year. Had it replaced and it does the same thing if it's not driven regularly. If it's driven frequently or tracked, it goes away. I'm having it done once more in the late summer before my warranty expires. I am requesting the 993 varient rms as it has a different seal clamping mechanism than the one used on 996 GT3 964 blocks.
Puddle was a bit bigger yesterday. Any Idea how long my dealer will need it to fix it? Car has only one DE day and 1600 miles.
I am suprised to here of so many GT3's having this problem. We are all aware of the vast problem with the regular 996 rear main seal problem, but typically the GT3 and turbo seals are far less likely to leak.
As stated before, the more one of these cars is driven, the less chance of oil leaks. The other function of oil (besides the obvious) is to keep the seals lubricated and moist. It is when the seals become dry that leaks start.
Kevin Hines
