New Alignment 997 GT3
I know that there has been a lot of discussion about a good alignment and sway bar settings. As such, we have all tried different variations this summer with varying degrees of success. All I have to say is that you should consider making a trip to FarnbacherLoles in Danbury CT before experimenting anymore.
If you haven't been to FarnbacherLoles, their facility is extremely well set up and very impressive. They have a massive work shop that is laid out like a museum. As an added bonus, you'll get to see various race cars in their shop. Their technicians are masters and very professional. They can attend to any need you might have with your car. As for the 997 GT3, there are many well laid out upgrades and power increases that can be performed. A special note is their new exhaust/header/cats combination that simply blew my ears out - it sounded like a Carrera GT on steriods.
997 Gt3
There is plenty of adjustability. As far as alignment specs - I started the summer with approximately -1.7F/-2.2R with a slight toe out in the front (sways set to 1 from soft front, full stiff in back). The car actually tracked fairly well with this set-up but was slightly darty on the road and definitely would step out if provoked. Of note was that understeer was fairly tame with this set-up. Now I have a set-up that is slightly more friendly on the street with loads of rear end grip in the rear. The new set-up is approximately even front and rear -2.0F/-2.0R (sways set 1 from stiff in front, and full soft in rear). Front toe is neutral. I also changed the rear toe links, lower control arms, and engine mounts. I have yet to fully test this set-up but by the seat of my pants the car seems real solid and stable with power on corner exit.
Rs Alignment Specs
I'v researched this topic on Rennlist a bit. Looks like the track specificspec is
front: -2.5 dge camber / 5' total toe IN
Rear: -2.4 deg. camber / 34' total toe in
I believe that the small amount of total toe in will greatly aid in straight line stability.
Can anyone with track experience confirm this please? Benifiting from other experienced drivers knowledge / testing to set the car up best as possible prior to first tracking it would be great.
Bob
Bob
do you happen to live in princeton sasportas?
sasportas......
Your absolutely correct in you view. I've know Spencer ***(speedsport) for years, way back prior to him joining forces with Dominik F. and although they specialize in Porsches, they have taken care of my e30 m3 since I've owned it and have done great improvments. Now that I'm a GT3 owner.....there's no other shop I would take my car to. Is anyone planning to attend next weeks ALMS at LimeRock?? I know Porsche NA will have a Corporate Hospitality Tent and you can get VIP ticket from your local Porche dealer(provided they like you) ......It would be nice to put faces to some of the names on this site
Alignment
I'm curioius as to how the car feels with -2.5 to -2.7 in the front. Is it very darty? Also, with greater than -2.2 camber in rear, I was getting a great deal of inside edge tire wear. I wonder when the new Toyo R888 becomes available if they will be OK with the greater camber?
pwdrhound
08-23-2015 07:36 PM
PelicanParts.com
997 Vendor Classifieds
08-20-2015 02:39 PM
PelicanParts.com
997 Turbo Vendor Classifieds
08-20-2015 02:38 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-20-2015 02:37 PM
2007, 6speedonline, 997, alignement, alignment, gt3, gt3rs, optimal, porsche, rs, sasportas, settings, specifications, specs, track
