"Kussmaul" suspension settings not achievable on a 100% stock 996 GT3...?
Old 06-30-2007 | 11:19 AM
Juha's Avatar
Juha is infamous around these parts
So I took my car in for an alignment yesterday. I asked the tech to set it up according to Kussmaul's recommodations for the street GT3.
He was able to match everything else, except for:
1. Ride height at front, Kussmaul 115mm, and my car would only go as low as 120mm.
2. Camber at front, Kussmaul -2.5 dgr, my car wold only go -1.4 dgr.
Now I'm obviously not too worried about the 5mm height difference but I'm wondering if the inadequate negative camber leaves me longing for something?
Is the car now really in "Kussmaul tune" with such a major difference up front?
Could this mean the car is more understeering than what it would be if the camber was set according to the specs?
I haven't had a chance to push the car yet after the alignment so I would see if it understeers now or anything, but for the 30 miles I drove with it yesterday, it feels absolutely beautiful! Huge difference to pre-alignment feel! (I don't know how much my alignment was off from the factory specs when we started but my tech told me he had to do a LOT of adjusting to get to the Kussmaul specs.)
Now the question is, should I get shorter springs to achieve that 5mm drop and more importantly get the camber to -2.5dgr...?
Also, are there aftermarket springs I could use with the stock shocks?
Thanks for your input in advance!!
Juha
Old 07-08-2007 | 06:23 PM
Moogle's Avatar
Moogle is infamous around these parts
you need to invert the position of the front springs to achieve the required level of ride height and camber.
Old 07-08-2007 | 07:55 PM
Juha's Avatar
yep! I got that reply at rennlist like 2 hours after posting the question...
Here it took 9 days to get an answer and you being on rennlist as well, I would say it's 1-0 for rennlist when it comes to technical questions...
Old 07-09-2007 | 02:00 PM
adam89911's Avatar
adam89911 is infamous around these parts
Negative camber up front
I have my car set at -1.8 degrees up front with no problems.
Adam
Old 07-09-2007 | 05:58 PM
Chris from Cali's Avatar
Chris from Cali has a reputation beyond reputeChris from Cali has a reputation beyond reputeChris from Cali has a reputation beyond reputeChris from Cali has a reputation beyond reputeChris from Cali has a reputation beyond reputeChris from Cali has a reputation beyond reputeChris from Cali has a reputation beyond reputeChris from Cali has a reputation beyond reputeChris from Cali has a reputation beyond reputeChris from Cali has a reputation beyond reputeChris from Cali has a reputation beyond repute
-2.5 degrees is a lot of negative camber for the fronts... I hope you've budgeted for tires since they will wear quickly (and unevenly) during normal driving. If this is your track-only car, please disregard.
Old 07-09-2007 | 06:56 PM
Juha's Avatar
That's what I was running on my M3 as well. Granted it eats the insides of the tires faster but I will be able to live with that knowing how much more grip I have while cornering.
I actually used to rotate my tires on the M3 for this very reason.
The GT3 is not a track only car but I don't drive it that much on the street either so it's no big deal. If it was a daily driver, -2.5 would be just too much.
Also, the geometry of the whole suspension has a big effect on tire wear.
-2.5dgr is a lot for some cars and not a big deal on others.
Thanks for the heads up though! Once I rotate the struts, my range will be from -2.5dgr to -4.0dgr...just like the cup cars come from the factory!
Old 07-09-2007 | 08:13 PM
Just saw your burnout pics... You are a wild man - just like your namesake...
http://en.wikipedia.org/wiki/Juha_Kankkunen
Old 07-09-2007 | 08:19 PM
Juha's Avatar
Juha Kankkunen asked my mom to marry him when they were both still in elementary school. And this is a true story...
Finland is a small country, Laukaa is an even smaller village and that's where both my mom and Juha Kankkunen are from.
I also know Kimi Räikkönen's wife Jenni. She's a good friend of mine's little sister...world is small!
I just wish I could drive like either of those guys!
Old 07-10-2007 | 04:03 AM
I am half-Finn myself (mom's side). Gotta love Suomi!
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
RS GT3 RS
09-24-2015 09:27 PM
08-19-2015 06:35 PM
ECS Tuning - VW
08-19-2015 02:15 PM
ECS Tuning - VW
08-18-2015 01:04 PM
Quick Reply: "Kussmaul" suspension settings not achievable on a 100% stock 996 GT3...?
