997GT3 TPMS Is Wacked!
My Tire Pressure Monitor System is going nuts all of the sudden. Warning light on telling me to add air when indicator and my Longacre gauge shows exactly 29/33 psi.
I even add air and reset the system to learn ect.,ect... But the warning light keep coming back on.
I've been told that TPMS is approx. 4 lbs. off, thus you would have to add +4 to each tire for the warning to go away. I would only use it if it indicated a sudden change in pressure, but not as an absolute.
When i bring it in for the break in oil change I'll have them check it.
Disable it. It is a useless option when tracking a car as your cold pressures will be much lower than the limit the monitoring system looks for. I had no idea they offered that option for 997 GT3's...hmmm
You reset it by going into the TPMS section of the computer (using the stalk on the steering column) and toggle it until you see set pressures or something like that.
Re-setting just temporarily fixed mine.
When I re-started the car it told me a different tire was 6 lbs. low.
Just spoke to the Master Tech at the dealer. Unfortunately this is a common problem in all 997 w/ TPMS . They can't shut it off due to Fed Regulation and there's no calibration device available either. Another word we f*ucked.
Originally Posted by grussell
You got that right! Rip out all of the electronics and install Motec engine management.
I had a feeling you're going there.
Just saw a 997Cup car that had M600 unit in it today at the track. The guy spent more time on his laptop tuning than actual driving.
Pista pro just like the picture.
For the money it is great! I have the Motec in my Cup but it was 14k so way too much for the pratice car. I think the Pista was 3k and I am very happy with it. You can set all of your own alarms and shift lights.
