BMC CRF -Carbon Racing Filters Air Intake Solution For The Lamborghini Gallardo/LP5XX
The CRF, Carbon Racing Filter, is BMC's new high performance sports air filter designed for road and competition vehicles. It features a 100% carbon fibre support structure with a cotton air filter.
The CRF has been designed and produced entirely by the BMC Racing and Advanced Composite Division, which is wholly concerned with the development of air filters and aspiration systems for the racing world: Formula 1 / MotoGP One / World Superbike. The CRF has been created from extensive BMC knowledge acquired through more than 10 years of experience in the racing sector, which has brought high level results and increased performance to super-sports engines.
The CRF air filter makes use of innovative technical solutions to optimize the flow dynamics of the direct air into the engine. The result is better air flow passage in the intake phase thereby maintaining constant air-box pressure.
The CRF filter was conceived with the objective of withstanding the vibrations and heat produced in movement both in normal road and intensive track use.
The CRF filter, as are all BMC filters, can be regenerated and reused. Once the saturation level has been reached the filter can be regenerated through a process of washing and re-oiling using the appropriate BMC washing kit.
Complete Carbon Fiber Air Intake System For LP 560 V10 Coupe - $3999.00
![](http://www.bmcairfilters.com/ThumbGen.ashx?path=/cgi-bin/images/product/crf705_01_kit1.JPG&border=False&width=400)
+ 40 HP
(Certified Bosch Dynotest - Stock car)
![](http://www.bmcairfilters.com/cgi-bin/images/product/crf704_01_dynotest.jpg)
Carbon Fiber Cylindrical Air Filter Kit For LP550-2 VALENTINO BALBONI/Spyder, LP560-4 Coupe/Spyder, LP570-4 SUPERLEGGERA/PERFORMANTE - $799.00
![](http://www.bmcairfilters.com/ThumbGen.ashx?path=/cgi-bin/images/product/crf605_08_3.jpg&border=False&width=400)
Also Avaliable OTA - OVAL TRUMPET AIRBOX For Lamborghini - Gallardo 04-09 Coupe - $899.00 Kit
It is a complete kit for engine air aspiration and filtration. This device is mainly composed of an oval-shaped air box in carbon fibre containing a cylindrical air filter with dynamic inlet. OTA kit totally replaces the original car filtration box (stock air-box).
![](http://www.bmcairfilters.com/ThumbGen.ashx?path=/cgi-bin/images/cat/ota_details_3d.jpg&border=False&width=200&force=False)
Usually the original car airboxes work in such a condition as the air is recalled by the engine in a "depression regime", through reduced section tubes, thus resulting in high load drop along the aspiration line. The OTA device with its dynamic inlet works in a "pressure regime", therefore it provides a constant and high rated quantity of air to the engine taking advantage of the dynamic effect of the air pressure.
In addition to its oval shape, offering high installation versatility, OTA system introduces in its inner part technical solutions which optimize the fluid dynamic of the air to the engine. In particular, the innovative element called "TRUMPET", which is situated inside the air box in the area close to the air outlet, thanks to its shape, favors and optimizes the convey of the air flow to the engine, resulting in the diminishing of turbulences. This solution reduces the pressure drop along the engine aspiration line and, at the same time, takes advantage of the potentiality of the dynamic pressure of the air caused by the speed of the moving car.
The air filter inside the air box 1 is made of a multi layer pre-oiled filtering material which grants an high filtration efficiency against limited pressure drop in the air. The air filter has the function of protecting the engine from all the elements (debris, sand, dust, etc…) in the air flow to the engine during the aspiration phase. BMC air filter has a very low drop (i.e. the pressure difference between the air flow at the engine side and the one at the air entrance side) in order to enable the maximum air flow.
BMC air filter can be regenerated and re-used. Once the saturation level has been reached, it is possible to
regenerate the filter by washing and re-oil operation performed by means of the relevant regeneration kit
![](http://www.bmcairfilters.com/ThumbGen.ashx?path=/cgi-bin/images/product/ota_piccolo.JPG&border=False&width=400)
![](http://www.bmcairfilters.com/ThumbGen.ashx?path=/cgi-bin/images/product/acotasp14_small.JPG&border=False&width=560)
And ofcourse a Performance BMC Replacement Filter is also Avaliable for all Lamborghini's
+ 40 HP
tropicatango
12-04-2015 02:45 PM
ECS Tuning - VW
08-19-2015 11:08 AM
