My Murcie is now a SV (AWD system delete)!
#32
Yes, we started with the Diablo SV setup as a starting point and tweaked from there. The whole car sits about 1/2" lower than stock and the only thing is now could use, especially as I go forward, is a functional wing due to the fact it's 300lbs. lighter than stock and has another 200+lbs. to go. That little stock wing in the back just won't cut it when the car is this light with this much more power!!!!
#33
You should go for the IMSA body kit setup, would definitely look clean and stylish in black.
#36
The IMSA allows for a 265 instead of the stock 235 (on 19s) or 245 (on 18s).
#41
+ 1
#42
This is very cool! I had no idea you could do this on a Murci! I also didn't know about the aftermarket wheel problems on them.... hmmmmm... thats not good at all!
Is there any kind of workaround for this other than removing AWD or getting aftermarkets of the same size?
#43
A 235/35/19 Front and 345/25/20 rear tire will always keep you safe.
