Macan not saving settings over and over again
Just wanted to know if anyone else seems to be having this problem and if so, any suggestions....
I have adjusted my settings on the PCM for door unlock, lock, comfort entry, auto circulate, etc.......to my liking at least 10 times and both when the car is moving and when it is not. For some reason, it does not save them and every time I get back into the vehicle, it goes right back to the factory default settings and I have to do them all over again.
Is there something I'm doing wrong? These settings are done the same way that it is done on my Panamera, but I have never had these issues with the panamera. Any help is appreciated.
I had the same complaint when I picked up my Macan. I found that the settings are registered to the key. When you set everything the way you want, save the settings to a memory button. Then it registers to the key. That worked for me.
There is also a setting on the MFD to save settings to the key when you lock the car. That way you would save the new settings to that specific key. Maybe a way to go it with the key button below to memory buttons on the floor also. But the auto store seems to be the easiest.
Porsche246
04-25-2016 09:07 PM
Rennen Modular
Wheels/Tires
01-12-2016 04:44 PM
