Two Weeks Left to Save Up To $175 On KW Suspension!
Many of you know that this September brought us the KW Suspensions' rebate special, a once-a-year deal to save big on better handling, a more comfortable ride, and an attractive look completely in your control.
The KW rebate is going on from now until the 30th. Don't miss the reduced price on our V1, V2, V3, and Clubsport's for selected KW applications. We've already had a few of our customers take advantage of these rebates. Message us if you'd like to add your Mercedes to that list or click the banner below to get started!
KW Variant 1 - SAVE $100
Sporty handling combined with sleek design.
Equipped with factory pre-configured damping.
The KW Variant 1 "inox-line" coil over kit is our entry model for increased driving pleasure with an attractive and individually adjustable lowering. Due to its high-quality finish, the use of struts made from stainless steel, corrosion resistant springs and bump stops as well as compatible components stands for long driving pleasure - not just the car's life.
Continuous lowering
KW Variant 2 - Save $125
For more stability and driving comfort.
Features adjustable rebound damping.
Drivers who want more than just an outstanding look and lowering within the TÜV-tested adjustment range will find our KW Variant 2 "inox-line" coil overs are their perfect suspension solution. The stainless steel struts with corrosion-resistant components provide unmatched durability and give you the possibility to adjust the dampers to your own requirements with 16 clicks of rebound setting.
More comfort or more sportiness - you decide!
KW Variant 3 - Save $150
Unlimited individuality for the street and bred from race technology.
Independently adjustable compression & rebound damping.
Our engineers have developed a sporty yet refined setup that allows you to individually adjust the compression & rebound damping independently of each other. To ensure we provide the perfect suspension setup we test them on our KW 7-post rig, as well as extensive driving tests on country roads, highways and even on the Nürburgring Nordschleife. For years, the KW Variant 3 "inox-line" coil over kit has been one of the top aftermarket products and a benchmark for coil overs. It has convinced sports car drivers, tuners, large and small series manufacturers such as Alpina, MTM, Manthey, Oettinger and many more industry leading companies in the international automotive industry with its damping characteristics, quality finish, and durability.
Advanced Technology bred on the racetrack, built for the road.
Clubsport - Save $175
The KW Clubsport coil overs utilize the uncompromising transfer of technology from the world of motorsports to track day/street driving.
The KW Clubsport coil overs combine KW's high-end racing technology with maintenance-free KW OEM components and TÜV certificate.
This will provide you the ideal product to take full potential of your sports car during track days, sports car driving clinics, enthusiast drives on Grand Prix circuits, and on tracks such as the Nürburgring Nordschleife.
Designed on the toughest race track in the world:
The Nürburgring Nordschleife
The KW Clubsport coil overs provide the ability to adjust for different track surfaces, sharp turns, and abrupt elevation changes. The KW Clubsport is in its home environment on the famous twists and turns of the 20.8 km long Nürburgring Nordschleife circuit.
While information is always good, they say pictures are worth a thousand words so we have those for you as well! Check out some of the images below to see what a stunning difference KW Suspensions can make for your Merc!
Continuous lowering
mdbonedoc
08-14-2016 10:30 AM
