Renntech lowering module
Just picked up a 2004 S430 4 Matic with the AMG kit on it for my daily. Just wondering if anyone has one of renntech's lowering modules on their benz, and if so have they had any issue's with the air suspension/ride quality?
Elm
Elm is probably the best option and the most expensive. There are two cheaper options that people are using with no problems. The first is new adj links www.adjustableairirde.com which replace your factory links and allows to lower the car much lower than the elm. the other is to get new oem s class links for the front and washers in the back. I dont really know the cons about the two methods but most say they have no problems yet.
hope this helps
hope this helps
Renntech is a great module. Let me know if you need one I can get it for you. You can adjust the ride height at all four corners individually. You don't have to cut any wires compared to the other brands.
adnanm3
11-22-2023 02:43 AM
proTUNING Freaks
09-15-2015 07:28 AM
