White CLK AMG Black Series with HRE M40
CLK 63 Black
Look's great ! Much more agressive than the stock turbine wheels. The car look's lowered esepcially in the rear ? Did you drop it to the DOT stops ? You can remove them and lower it even a little more. Car likes 2 to 2.5 degrees neg. camber. The front end really bites on turn in with better contact patch. I don't think you would shorten the tire life too much. What tires did you use ? HRE used my Black at SEMA with the same 20's on it. I chose to use 19's in the new C-90's PS-2's 275 & 295 30's. They feel the same as the Corsa's as far as I can tell. Haven't driven it in the dry very much so I will have to do more testing. Good choice and good luck with the car. Steve
