Car For Sale 2005 Hummer H2
Old 06-20-2008 | 03:11 AM
DanielTao007's Avatar
DanielTao007 is infamous around these parts
We have 2005 Hummer H2 Car For Sale.
  • 5,967 cc 6 liters V 8 front engine with 101.6 mm bore, 92 mm stroke, 9.4 compression ratio, overhead valve and two valves per cylinder LQ4
  • Multi-point injection fuel system
  • Unleaded fuel 87
  • Power: 242 kW , 325 HP SAE @ 5,200 rpm; 365 ft lb , 495 Nm @ 3,600 rpm
  • Torsion beam front suspension independent with stabilizer bar and coil springs , trailing arm rear suspension rigid with stabilizer bar and coil springs
  • Automatic four-speed transmission with mode select, lock-up, electronic control, shift lever on floor, 3.06:1 first gear ratio, 1.62:1 second gear ratio, 1:1 third gear ratio, 0.69:1 fourth gear ratio, 2.29:1 reverse gear ratio, low/high gear ranges and 2.64:1 low/high gear ratio 4L65-E and automatic.
If You Are Interested Please Contact at : 919-957-0200
Old 06-20-2008 | 05:41 AM
Dupes's Avatar
Dupes is infamous around these parts
how much?
a bit more info would be nice!
Old 06-20-2008 | 08:16 AM
Jay Slay's Avatar
Jay Slay has a spectacular aura aboutJay Slay has a spectacular aura about
Why is this in the MBenz forum?
Old 06-20-2008 | 08:20 AM
saintv90's Avatar
saintv90 is infamous around these parts
There is a For Sale Section...but you need 100 posts.
Old 06-20-2008 | 08:37 AM
Jay Slay's Avatar
So put it in the American Car forums...
Old 06-20-2008 | 12:31 PM
Reve1's Avatar
Reve1 is infamous around these parts
Because Mercedes drives like a Hummer?
Old 06-21-2008 | 11:03 PM
mr2guysingh's Avatar
mr2guysingh is a splendid one to beholdmr2guysingh is a splendid one to beholdmr2guysingh is a splendid one to beholdmr2guysingh is a splendid one to beholdmr2guysingh is a splendid one to beholdmr2guysingh is a splendid one to behold
50 Usd Cash!!!
Old 06-22-2008 | 06:57 AM
jstrat85's Avatar
jstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to all
you need at least 100 post before you can sell anything!!!
COBB Tuning
01-29-2022 09:42 AM
2lflat4
11-18-2019 05:05 PM
PorscheEnthusiast
11-13-2015 02:23 PM
ModBargains
Audi Vendor Classifieds
09-01-2015 05:26 PM
manishdutta
08-21-2015 09:49 AM
Quick Reply: Car For Sale 2005 Hummer H2
