Mercedes E/CLS/SL 55 AMG Performance Rotor Kit
Old 10-21-2008 | 03:14 PM
GMP Performance's Avatar
Site Sponsor
Note: E55. brakes shown
Performance Rotor Kit (DRILLED/SLOTTED). Includes front and rear multi-piece floating rotors - Front 14.2"/360mm, Rear 13.0"/330mm. For use with OE AMG brake calipers only - E/CLS 55 AMG Kompressor
Designed as a direct brake disc replacement for the OE 55 AMG brake discs on all four corners (No modifications are necessary. The disc will bolt directly to the car and work with OE AMG brake calipers). Not only will the upgraded multi-piece "floating" discs help mitigate brake fade, but are lighter than stock and reduce unsprung weight by a total of 34lbs. on all four corners! This means better acceleration, braking and cornering. In addition, you get to maintain the AMG calipers without going to a more expensive solution that requires replacing them. Available drilled or slotted or slotted.
Old 10-21-2008 | 03:16 PM
Site Sponsor
Just wanted to let you guys know we are now carrying these as well. If you have any questions, ask away!
Old 10-23-2008 | 02:58 PM
Jorgeassoc's Avatar
Jorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant future
Did Evosport make this?
Old 10-23-2008 | 03:13 PM
Site Sponsor
oops sorry, yes we buy these from Evosport...
Old 10-24-2008 | 11:53 AM
humveelat's Avatar
humveelat is infamous around these parts
Whoa! That's a nice rotor kit. Sweet..
Armytrix_F1_Exhaust
07-08-2019 12:31 AM
09-01-2015 04:16 PM
08-21-2015 07:34 AM
ECS Tuning - VW
08-20-2015 04:07 PM
