Mercedes Service H?
that'd be a b-service and whatever is additionally needed based on time and mileage. theres a way to look it up in the cluster. it will tell you the service #'s needed but you need the maint. sheet to determine what the number stands for.
b-service typically includes oil change, major service inspection over vehicle (leaks, suspension, tires, etc...), battery test, wipers and interior cabin filters. Additional services are not included such as brake flush due every 2 yrs (standard maint on all makes/models fluid is hydroscopic which means it will absorb water and corrode components), transmission service due at 39k, engine air filters at 60k, sparkplugs at 80k (says you can stretch to 100k but i wouldnt wait that long), says fuel filter at 65kish but i wouldnt bother with that its part of the sending unit and i've never seen one clogged, supercharger belt ever 4yrs might as well do the other belt while your at it since labor should be the same for one or both. thats pretty much all there is too it unless you need other things found during the inspection. so it'll be a B-service + whatever your car needs based on time/mileage
Armytrix_F1_Exhaust
07-07-2019 11:31 PM
HotRod
09-10-2015 07:17 PM
