My first MB...2005 SL65... baselined
Old 09-19-2013 | 03:33 PM
vrybad's Avatar
vrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant future
Originally Posted by ALPINE6SPD
I would be curious to know if muffler delete would add power. It might but it also might take away some low end torque. Email me pis of the RS6 to ryanguercio@gmail.com thanks.
Now that right there is funny!
Absolutely no lack of torque in that thing!
Old 09-20-2013 | 08:20 AM
ALPINE6SPD's Avatar
ALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant future
I know that torque is not any issue in the car I was just pointing out that typically you could lose torque by doing so. Was just saying it could happen and not that it was an issue.
Old 09-20-2013 | 08:27 AM
ttboost's Avatar
I'm hoping it will happen...
Old 09-21-2013 | 08:35 AM
vrybad's Avatar
No such luck there, bro!
Stickier tires are in your future!
Old 10-24-2013 | 07:30 PM
ttboost's Avatar
Finally got on the dyno with my new Eurocharged tune. 530/754 on a Mustang dyno. No huge peak HP gains, but major "under the curve' power improvements. 30-60whp gains and 100-120wtq gains.
Old 10-24-2013 | 10:46 PM
Bobbyfali's Avatar
Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !
530 and 754 on EPL Mustang dyno with just flash!
Very impressed, I knew this car would make big power effortlessly, with the cubes and twin turbo!! This was one of the cars that I was looking at before the Turbo.
I will be following your machine to see how it responds with your future mods.
What build do you have in mind with this machine?
Do you live near EPL?
I am going to coming down to EPL from Toronto, Canada in about 2-3weeks To get my new set up strapped and tuned by Tony.
Bobby Ali
ba
Old 10-25-2013 | 12:09 AM
cuemaster's Avatar
cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !
fantastic cars the 55 and 65 enjoy, keep the painted side up.
Old 10-25-2013 | 05:19 AM
ttboost's Avatar
Thanks Guys. Yes, I live 20min from EPL. I will likely do a trunk coolant tank over the Winter, which won't net me any more power, but will allow me to have the same power longer. Probably a turbo upgrade in the future..which will likely lead to a transmission upgrade which wi....oh crap.....
Old 10-28-2013 | 07:08 AM
Slik560's Avatar
Slik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond repute
Not bad for a first Benz. Enjoy.
Old 11-09-2013 | 07:16 PM
ttboost's Avatar
OK..back to the track today...new numbers from
Atco..unfortunately it was Chevy day..all the Vettes, Camaros and Chevelles you can shake a stick at...got in line at 9:45am...first run at 11:30, 2nd run at 1pm...left after that...spun pretty bad the first pass and not so bad the second pass...had some fairly beat up DR's...Best 0-60 was 3.2.
ID:	298778   Click image for larger version
Old 11-11-2013 | 07:23 PM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
Congrats ttboost! I admit I've been following these cars a bit and have a few ideas I'd like to try out. I noticed you were asking Marcin about 18g upgrades and for whatever its worth, the stock m275 compressors are already at the 18g-like level with BW 2474 wheels. The black series have 2480s which are similar to 20g's. You'll see the 2474 & 2480 used in European Porsche K24 upgrades, both of which use fairly recent extended tip technology and are relatively lightweight (996TT X-50 uses the older 2470 compressor). I'd want at least an HTA 68mm billet wheel in there for a hybrid and even that may be on the small side!
Looking forward to more of your updates!
Old 11-11-2013 | 07:29 PM
ttboost's Avatar
Thanks for the info!!! Been looking for info like that. No one is really that forthcoming. Apparently it is inconceivable for someone to work on their own car. It seems if they cannot make money on you, they're out. My current mods are front mount heat exchanger, no mufflers, Bosch 010 IC pump and a stage 2 Eurocharged flash. I have no interest in upgrading my turbos unless my engine has to come out for something else. Right now I am considering a trunk resevoir and a meth kit. Oh..and some new tires...
Old 11-12-2013 | 02:49 PM
tracshun's Avatar
tracshun is infamous around these parts
Tires were fine - burnouts were horrible
Old 11-12-2013 | 04:38 PM
Bobbyfali's Avatar
I would love to see what meth would do with this machine!
Bobby Ali
ba
Old 11-18-2013 | 10:01 AM
Shardul's Avatar
Shardul is infamous around these parts
Methanol will keep the power more consistent. I would use a small jet pre tb just to cool the intake charge that's it.
With a methanol kit you wont need a rear tank anymore.
Quick Reply: My first MB...2005 SL65... baselined
