Kleeman K2
Kleeman K2
My SL55 went to the tuners on Monday for the upgrade. I wonder what the "after" dyno will read.
I just got this email below.
Yes, Cory emailed me the procedure to dyno your car.
You as well as others say our dyno reads low, we like to say it is accurate. Dyno Dynamics have been in business for over 25 years. Dyno Dynamics builds both engine and chassis dynos so they have worked with auto manufacturers by dynoing motors on an engine dyno, installing the motors in vehicles and then dynoing them on their chassis dynos. This information has been used in creating the software used in our chassis dyno to calculate drivetrain losses to get HP numbers at the wheels. Another thing to consider is that our dyno is a true load bearing dyno. Other dyno’s like a Mustang are inertia passed so I like to equate these dynos to running down hill. Once you start it is easier to keep going faster since you have the momentum.
If Edmunds.com is correct stock is 496HP and torque is 516 ft-lbs at the FLYWHEEL for a 2005 SL55 AMG.
Our dyno has built in software to estimate flywheel horsepower, we don’t like to publish the numbers because it is one more thing for people to get confused over.
We ran your MB in this mode and it showed 492 hp and 540 ft-lbs estimated at the FLYWHEEL. So if you were to look at these numbers the dyno is nearly spot on for HP and actually shows your car to have more torque than what the factory claimed.
I hope the above explains how Dyno Dynamics have developed there software and why the numbers are what they are.
The pulley and filters are installed, passenger side header is in. The ECU will be back today and the rest of the header system will be installed. I am hoping that everything is finished up by end of day today.
I will keep you posted.
Thanks,
Scott Bertz
KTR Performance
978-772-9911
Thanks,
Scott Bertz
KTR Performance
978-772-9911
Great to know you have more torque than stock, There is a larger throttle body for the AMG 55K vehicles they came on the 2003 SL55's I think they are 88mm's and they increase hp to 520, I found that in mbworld
Have you had the MB recall done yet with the new ECU flash? I am hearing that the hp and torque will drop after this service. They are pulling the down the load limits of the motor in the microcode.
B Feelgood
09-29-2014 05:54 PM
GMP Performance
11-06-2012 07:03 AM
