56hp and 84lbs tq for $1,200!
Not only a different crank pulley, but a blower snout pulley. The kompressor is creating too much pressure, and the pressure has to release somewhere because it is not being used...causing it to blow the gaskets.
This is news to me....
I have been reading ALOT about the 55k mods from both RENNtech and Kleenman and there have been almost 0 problems.....
I think a stage 1 (software, and ecu) is very safe on this car. The only issue with these mods is that the intercooler is very inefficient. The extra heat from the mods show the weakness of the intercooler.
Its not the car becoming over heated, its just the intercooler doesn’t become efficient enough to cool down the "charge" air before it enters the manifold.
You basically loose a lot of horsepower when the car has been driven hard.
Renntech and evosport both make cooling packages
i have a 05 e55 btw
i have a 05 e55 btw
Originally Posted by DrivenAgain
I am familiar with blown head gaskets, just not on the 55 Kompressor motors...I can only recall one from that I am familliar with. Was this a RENNtech or Kleemann modified 55 and did it have any type of intercooler upgrade?
The 55's have no issues running the larger crank pulley. The only issue I would see with a crank pulley mod only is the AFR (corrected by ECU).
Full everything, crank AND SNOUT pulley. It took some guys over in Denmark 3 weeks to make the snout pulley.
How much boost and what kind of car (55 w211)? If it was the snout (supercharger) pulley on an 55 the blower clutch will fail (it is all one unit). That is the primary reason all of the tuners provide a Crank pulley not a Snout pulley on a 55.
An e55 will actually loose boost (intake pressure) with headers because of lower restiriction. A PROPERLY designed crank pulley will only produce 3-4 addtl psi (safe). Total of 14-15psi
It sounds like the guys in Denmark really had a lot of overdrive on the blower and screwed up the clutch. If you are running 17-18psi you will have issues. In any event the bypass valve would still bleed off the extra (bad) boost.
Originally Posted by DFW911T
HD was this pulley on the s/c your design/idea or was your car serving as a test platform for a tuner?
VID997
97
03-20-2018 02:23 PM
dhahlen
11-05-2015 12:55 PM
