:: ECS Tuning :: So Much More......... Gen 1 MINIs
ECS Tuning
MINI R52 S /R53 S Thermostat Housing
Do you have a leak on the driver side near the transmission and engine connection, dripping down the side of the engine? This is most likely the problem.
The housing is prone to cracking with many heat cycles and miles. Now from Vaico we have another solution.
This housing buttons up with three bolts to the side of the head and compresses the double circle gasket on the thermostat itself.
Fits:
R52 MINI Cooper Convertible S/ JCW (2005-2008)
R53 MINI Cooper S/ JCW (2002-2006)
Click HERE For MINI Cooper S, JCW (2002-2008) Options
ECS Assembled | MINI R52 R53
All-in-one kits that take the guesswork out of what you really need to keep your MIN performing at its best. From full Cooling System Refreshes, Oil Service Kits, and Automatic Trans Services kits, and beyond.
Specifically put together by ECS Tuning specialists, Assembled by ECS kits give you the piece of mind that the job is complete.
Fits:
R53 MINI Cooper S (2002-2006)
R52 MINI Cooper Convertible S (2002-2006)
Click below for you model.
Click HERE For Cooper S, JCW (2002-2008) Options
CSF Performance Aluminum Radiator | MINI R52 R53
CSF is a leader in automotive cooling technology, with over a half-century of experience. Using that knowledge, they have developed this high-performance radiator that far surpasses the abilities of the stock unit. Starting with a two-row, triple-pass design for the coolest temperatures possible, this radiator features high-quality CNC-machined brackets and hardware. To finish it off, each radiator is hand polished to a mirror finish for that show-car shine. Best of all, it fits like the stock part, requiring no modifications for installation. Made as a direct fit to from your stock
Keep It Cool
Fits: MINI
Click HERE For R53 / R52 S / JCW Options
Sprint Booster Power Module | R50/R52/R53 MINI
Does your drive-by-wire throttle need a wake up call? Is there an annoying lag between pedal mashing and engine giddy?
Modern drive-by-wire throttles are electrically operated, and some take their sweet time responding when you stomp on the gas.
Sprint Booster has the solution. This plug and play signal enhancer installs in minutes to improve throttle response and performance.
Complete with remote, push button control to let you select among stock, sport, or race modes for different driving conditions.
Instant Throttle Response
Fits:
R50 MINI Cooper (2002-2006)
R53 MINI Cooper / S/ JCW (2002-2006)
Click HERE For MINI Cooper Gen 1 Options
Fits:
Fits:
Keep It Cool
Fits: MINI
Fits:
stigt30r
01-17-2016 12:34 PM
