LOTS of Mini Questions..
Hey guys, I've recently been looking into getting a mini cooper S mt.
I'am going to completley repaint it, turbo/sc it, (not sure which yet) any insight would be good..
However, I came upon some stats today that say the S only makes 186hp I beleive?
Now, if I were to say turbo/sc this, and it being so light 2600lbs? could it be a potential killer on the street even though it won't have gobs of power? (I'm thinking with a car this light, I won't need 1000hp lol)
And what kits are available right now for f/i with it?
Will 650 hp work? This Mini is a monster! Check out this vid Mini Cooper S vs E92 M3 SC (500+ hp):
http://www.youtube.com/watch?v=TCJqcfaDKDE
It was converted to AWD
You may find some answers at www.northamericanmotoring.com
"Only" 365hp in an MCS?
That is enough to twist your wrists off.
I'm sorry if I'm getting u guys turned down but in reality its not easy to turn a Mini into a monster. I'm not saying it can't be done but you need lots of time and $$$$ in order to do so. The main issue you have to consider before installing a big turbo kit on a MCS is the amount of traction you will have, you will either burn the crap out of your front tires with the ESP off or you won't go anywhere with the ESP on. Unless if you can turn the monster into a 4WD than you can increase as much hp as you want, otherwise don't waste the money, you will be much happier with a Subaru STI for a similar price.
There are still some Alta twurbo kits floating around that uses the S supercharger and the Alta Turbo Kit. check northamericanmotoring marketplace , motoring underground, motoring alliance. would be amazing.
Here is a video from PINKS All Out Englishtown 2008
http://www.youtube.com/watch?v=i33lTY-AH4g
Hey Buddddddy.....I was just going to correct them.... Stoopid Mini's and their expensive modding...pffft. BTW, I need to put the starter in mine to get it back on the road this weekend. You down to help?
PelicanParts.com
09-08-2015 03:10 PM
ECS Tuning - BMW
09-02-2015 02:11 PM
ECS Tuning - BMW
09-02-2015 01:57 PM
