New shoot of my MINI S !
2004 MINI Cooper S
19 PSI BOOST
Electric Blue Metallic
White Roof/ Mirrors
6 Speed Manual
-Current Modifications-
Under the Bonnet :
Magnaflow Performance Muffler
Magnaflow Hi-Flow Cat
Modified S Header, Removed Pre-Cat
Hi-Flow Resonator
Flowmaster 3.5" Tips (flat black)
Crower NS1 Camshaft
ALTA 17% v2.0 Pulley
ALTA v2.0 Cold Air Intake
ALTA Red Silicone Tube
ALTA Tensioner Stop
NAPA 535 Belt
MSD Ignition Coil
JCW BKR7EQUP Spark Plugs
Kingsborne 8MM Red Spark Plug Wires
Detroit Tuned ByPass Valve
X02 Larger Intercooler (grinded below to make clearance)
ALTA TMIC Air Diverter (custom welded/ flat black)
Intercooler Sprayer hooked up to Diverter
M7 400cc Injectors
180F Thermostat
Powerflex Upper Engine Small Polyurethane Bushings
Powerflex Upper Engine Large Polyurethane Bushings
Powerflex Gear Box Mount Polyurethane Bushings
Sprint Booster Throttle Power Converter Race Program
Fierce Eyes Under Bonnet
Transmission:
ClutchMasters FX200 Clutch
Clutchmasters Lightened Flywheel
Suspension :
Tein S.Tech Lowering Springs
Powerflex Control Arm Polyurethane Bushings
Front Strut Tower Bar
Rear Strut Tower Bar
Wheels and Tires :
Rota GT3 16x7 4x100 +40mm offset 67.1mm bore White w/polished lip
P215/50R16 Dunlop DZ High Performance Summer Tires
Hub Centric Rings
Custom Alignment
Brakes :
Carbotech 1521 pads
SS brake lines (Ireland Engineering)
ATE Slotted Rotors
Red Painted Calipers
ATE Super Blue Brake Fluid
Exterior :
Shaved bonnet Badge
Shaved boot Badge
Shaved license plate holes
Black Aero Grill
Clear Taillights
Side Marker/Turn Signal Stealth Bulbs
Disabled lower bumper bulbs
Disabled Side Reflector bulbs
8500k Headlight bulbs
White LED License Plate bulbs
Clear Side Reflectors
Boot Debadged
Rear Wiper Removed (1" cap in hole)
Stubby Antenna
Hole-less License Plate Holder
Custom License Plates LILMINI
EB S Sidemarker Emblems
Removed Driving Lights
Daytime Running Lights Off
ALTA License Plate Frame
Custom Fabbed Plate Bracket
Interior :
M7 Carbon Fiber Shift ****
5% Window Tint
Front Window 20% Tint Banner
Auto Meter 4401 Boost Gauge (Blue LED)
Auto Meter 3204 Mounting Cup
Blue LED Dome light bulbs
Windows Auto Up Circuit Mod
DSC Auto Off Circuit Mod
Storage Tray Set - 2 Piece Set
Dash Pillar Cup Holder
ICE :
Its a Secret...
Labor :
New Inner and Outer Ball Joints
New Tie Rods and Inner/Outer Tie Rod Ends
New boot lock/handle
Updated to newer door handles
Removed Rattles from Dash & Boot
Shaved badges and painted keyed marks
-Mods to come-
Snow Performance Water/Meth
Thumper Ported Head w Springs
M7 Oil Catch Can
Mini Madness Ported Intake Manifold
Door Lock Actuator
Cabrio Cross Braces
Lower Engine Mount Polyurethane Bushings
ALTA 22mm Rear Sway Bar
ALTA EndLinks
Short Shifter
Mynes Custom Flash Tune and Dyno
Intercooler for awhile.
back to stock Intercooler for higher boost.
ECS Tuning - BMW
10-01-2015 01:35 PM
ECS Tuning - BMW
10-01-2015 01:29 PM
ModBargains.com
996 Turbo Vendor Classifieds
10-01-2015 11:48 AM
ECS Tuning - BMW
09-29-2015 01:18 PM
