Nissan GTR Forum for the R32, R33, R34 and R35 "Godzilla"
GT-R Unveiled
Old 10-20-2007, 06:23 AM
Chuck_H's Avatar
Chuck_H is infamous around these parts
Here is one thread with all the GT-R pics/articles so far.
http://www.nagtroc.org/forums/Offici...ad-t20099.html
Old 10-20-2007, 09:08 AM
mav16's Avatar
mav16 is infamous around these parts
I still want to see this car in person but so far I'm disappointed.
The front looks like an Eclipse, the interior looks like too 1980-ish and overall it isn't nearly as aggressive as it should be.
Put the black mask back on.
Old 10-20-2007, 02:27 PM
IIVVX's Avatar
IIVVX is infamous around these partsIIVVX is infamous around these parts
agreed, interior looks like crap
Old 10-20-2007, 07:41 PM
SoCal955's Avatar
SoCal955 is infamous around these parts
Can't help feeling a little disappointed with the direction they went with the exterior. Way to much hype over the past few years, and it doesn't quite live up to it. Numbers wise the thing seems awesome, but the look????
Will have to wait and see it in person.
Old 10-21-2007, 01:29 PM
unvmy996's Avatar
um, it will be cool to see what kind of power they squeeze out of it , and to see if its as mod freindly as the previous one, but other than that it does nothing fo me.. i think its ugly, looks like a gloryfied Altima . and the the big gap in teh center console is horrid.
Old 10-22-2007, 01:50 AM
ChromeHearts's Avatar
ChromeHearts is infamous around these parts
looks like a japanese corvette from the rear. Interior looks haphazardly thrown together (no manual tranny?) and the front is disgusting
Old 10-22-2007, 01:57 PM
kingleh's Avatar
kingleh is a glorious beacon of lightkingleh is a glorious beacon of lightkingleh is a glorious beacon of lightkingleh is a glorious beacon of lightkingleh is a glorious beacon of light
internet arguing is NOT aloud..
lol
Old 10-22-2007, 06:31 PM
djomlas's Avatar
djomlas is infamous around these parts
looks like a mix of 350Z and rear of a new camaro
i bet its got *****
Old 10-24-2007, 08:26 AM
WMP's Avatar
WMP
WMP is offline
WMP is infamous around these parts
Official specs from Nissan...
http://www.gtrnissan.com/specs.en.us.html
SpecificationsEngine
• VR-series twin-turbocharged 3.8-liter V6.
• 480 hp @ 6,800 rpm. 430 lb-ft torque @ 3,200–5,200 rpm.
• Dual overhead camshafts with variable intake-valve timing.
• Cast aluminum cylinder block with high-endurance/low-friction plasma-sprayed bores.
• IHI twin turbochargers, one per cylinder bank.
• Pressurized lubrication system with thermostatically controlled cooling.
Drivetrain
• ATTESA ET-S All-Wheel Drive (AWD) with independent rear-mounted transaxle integrating transmission, differential and AWD transfer case.
• Rigid, lightweight carbon-composite driveshaft between engine and transaxle.
• Electronic traction control plus 1.5-way mechanically locking rear differential.
• Vehicle Dynamics Control (VDC-R) with three driver-selectable settings: Normal (for daily driving, controls brakes and engine output), R-Mode (for ultimate performance, utilizes AWD torque distribution for additional vehicle stability) and Off (driver does not want the help of the system).
• Hill Start Assist prevents rollback when starting on an incline.
DisclaimerVDC-R cannot prevent accidents due to abrupt steering, carelessness, or dangerous driving techniques. Always drive safely.
Transmission
• 6-speed Dual Clutch Transmission with three driver-selectable modes: Normal (for maximum smoothness and efficiency), Snow (for gentler starting and shifting on slippery surfaces), and R mode (for maximum performance with fastest shifts).
• Fully automatic shifting or full sequential manual control via gearshift or steering wheel-mounted paddle shifters.
• Dual clutch design changes gears in less than 0.5 second (0.2 second in R mode).
• Downshift Rev Matching (DRM).
• Predictive pre-shift control (in R mode) based on throttle position, vehicle speed, braking and other information.
Wheels and Tires
• 20 x 9.5" (front) and 20 x 10.5" (rear) super-lightweight forged-aluminum wheels with Gunmetal Gray finish.
• Exclusively developed nitrogen-filled Bridgestone® RE070A high-capacity run-flat summer tires, 255/40R20 front and 285/35R20 rear.
• Tire Pressure Monitoring System (TPMS).
• Optional exclusively developed nitrogen-filled Dunlop® run-flat all-season tires, 255/40R20 front and 285/35R20 rear (includes Bright Silver wheels).
Brakes
• Brembo® 4-wheel disc brakes with 4-wheel Antilock Braking System (ABS), Brake Assist, Electronic Brakeforce Distribution and Preview Braking.
• Two-piece floating-rotor 15-inch front and rear discs with diamond-pattern internal ventilation.
• 6-piston front/4-piston rear monoblock calipers.
Steering
• Rack-and-pinion steering with vehicle-speed-sensitive power assist.
• 2.6 steering-wheel turns lock-to-lock.
Suspension
• 4-wheel independent suspension with Bilstein® DampTronic system with three driver-selectable modes: Normal/Sport (for automatic electronic control of damping), Comfort (for maximum ride comfort), and R mode (engages maximum damping rate for high-performance cornering).
• Electronically controlled variable-rate shock absorbers. High-accuracy progressive-rate coil springs.
• Front double-wishbone/rear multi-link configuration with aluminum members and rigid aluminum subframes.
• Hollow front and rear stabilizer bars.
Body/Chassis
• Exclusive Premium Midship platform with jig-welded hybrid unibody.
• Aluminum hood, trunk and door skins. Die-cast aluminum door structures.
• Carbon-reinforced front crossmember/radiator support.
Old 10-24-2007, 09:34 AM
ConceptualMind's Avatar
ConceptualMind is infamous around these parts
Some more pictures from the Tokyo Auto Show:
http://www.autoblog.com/2007/10/24/t...e-nissan-gt-r/
Old 10-24-2007, 12:44 PM
KeyserSoze's Avatar
KeyserSoze is infamous around these parts
more pics, up close and personal...
http://www.autoblog.com/2007/10/24/u...e-nissan-gt-r/
Old 10-24-2007, 06:45 PM
hm, I'm still not sure whether or not I like the styling. It definetely doesn't look bad though, but I'm not drooling over it yet.
Old 10-25-2007, 09:49 AM
Vantage's Avatar
Vantage is infamous around these parts
The profile looks a little too much like a pumped up G35 coupe and the interior doesn't blow me away.
It's a dream come true for Gran Turismo fanboys however..
Old 10-26-2007, 08:46 AM
Crea's Avatar
Crea is a jewel in the roughCrea is a jewel in the roughCrea is a jewel in the roughCrea is a jewel in the rough
lol
its developed WITH Gran Turismo ppl too!!!
I guess the only reason the GTR is so popular worldwide is becuz of Gran Turismo...
Old 10-26-2007, 08:50 AM
IIVVX's Avatar
http://en.wikipedia.org/wiki/Skyline_gtr
Quick Reply: GT-R Unveiled
