TopSpeed AMS Turbo Upgrade and Intercooler Sale
AMS Nissan R35 GT-R Front Mount Intercooler
The AMS Nissan R35 GT-R Front Mount Intercooler is one of the best performing
intercooler upgrades you can buy and has the 9 second time slips to back it up. This is the same durable, race proven front mount intercooler used in our world record setting SR850 package. This direct bolt-on intercooler has over 30% more internal flow area than its stock counterpart, works with stock piping and does not require any cutting or trimming! This intercooler bolts on so nice and clean you would swear it was an OEM Nissan piece!!
The AMS Intercooler features cast aluminum end tanks for added durability with extremely smooth features and geometry. Designed by our engineering team using Solidworks (3D CAD software) these A356 T6 Alloy Aluminum end tanks have improved flow over sheet metal end tanks and include integrated OEM location mounting brackets for ease of installation. Custom molded silicone couplers are included to optimize airflow volume and velocity which feed the 3” inlet and outlet ports.
AMS goes beyond our competition to ensure quality; each AMS Intercooler is hand TIG welded in a jig for a perfect fit and pressure tested to 50 psi to ensure maximum performance.
We tested many intercooler cores to find the best performing unit available. Over the past 9 years AMS has tested just about every core available to source the best manufacturer for our kits. The R35 GT-R intercooler is no exception as this core is manufactured by the same company used for our 1400HP drag cars and time attack race team.
Call or PM for Special 6SpeedOnline Pricing
Features
Supported the first 9 second GT-R in the world
Direct bolt-on requires NO cutting or trimming
30% more internal flow area than stock
Smooth flowing cast end tanks allow for better airflow over the competitions sheet metal units
Custom molded silicone couplers to optimize airflow volume and velocity.
Will bolt up to stock piping or most aftermarket pipe kits that are designed for the stock intercooler
Bar and plate intercooler core, the best performing on the market!
OEM-like fit and finish
All AMS intercoolers are pressure tested after assembly to 50 psi
Kit Includes
Hose clamps
Specifications
Intercooler core dimensions: 9” tall, 22” wide and 4” thick
Supports up to 1200HP
Comes with black “AMS” painted logo
Applications
09 + Nissan R35 GT-R
The AMS GT-R Turbo Upgrade provides stock spool up, neck snapping torque and horsepower that will transform the already mighty GT-R into a true supercar! Designed as a direct bolt on for your existing factory turbochargers, you can expect gains starting at 170whp/150wtq and up with the proper supporting mods and tuning! At full boost with race gas these turbos are capable of up to 850 horsepower!
These turbos were designed to mimic spool and the aesthetics of the factory units. To the untrained eye these two turbos looks just as quiet and unsuspecting as the stock turbos but once you hit the throttle the difference becomes very evident.
On our chassis dyno with just an AMS Turbo-Back Exhaust, boost controller, upgraded injectors and a tune we were able to take our stock GT-R safely from 434 all wheel horsepower all the way up to 610! Torque was also bumped from the stock level of 406 to a massive 581 ft lbs measured at the wheels!!! Most impressive of all, this was done on JUST 22psi and 93 OCTANE PUMP GAS!
These are the same race-proven turbo's found on our 9 second SR850 GT-R and both the Cobb Tuning and Forged Performance Time Attack cars so you can expect the best results.
Call or PM for Special 6speedonline Pricing
Exclusive Features
Direct factory replacement with NO cutting or trimming required
Capable of up to 850hp depending on boost and octane level
170 wheel horsepower and 150ft lbs of torque gains on just pump gas!
Factory like fitment, even incorporates the factory heat shielding
Bolts right up to the stock piping and intake system.
OEM look that is hard to detect
Utilizes machined OEM turbine and compressor housings
Assembled with a True Garrett GT series ball bearing center section
Ability to reuse the factory wastegate actuators (for increased performance add on the Forge wastegate actuators)
Specifications
Garrett GT Ball Bearing center section with machined OEM housings
Comes complete with oil and water lines for easy installation
Options
Available with Forge wastegate actuators
Applications
2008 and up Nissan GT-R’s
Fits all USDM models. (JDM and European models have not yet been tested)
Please note this item requires the buyer to send in their factory/stock turbos in as a core. Failing to do so will result in a core charge equal to the market price of a new set of factory/stock turbo chargers.
Features
Kit Includes
Hose clamps
Specifications
Applications
Exclusive Features
Specifications
Options
Applications
We really appreciate the business and support from the community guys!
~Cicio
cicio@topspeedmotorsports.com
www.topspeedmotorsports.com
-FASTEST 991 Turbo in the WORLD: 201.97 MPH
-HIGHEST HP 991 in the WORLD: 1287whp
-991 Turbo S Build Thread
-COBB ProTuner
-Syvecs Dealer / Tuner
-Complete in House Builds
~Cicio
-COBB ProTuner
Mackchacha
07-09-2019 11:03 AM
3WDistributing
31
10-27-2017 01:26 PM
ECS Tuning - VW
08-19-2015 08:58 AM
