Switzer R1KX on the way
#529
D@mn!
I just skipped to th elast two pages in the thread, but SWEET L0RD those numbers are insane!! Now I have to go back and read how that is even possible!
#530
Plus, 100 octane is 100 octane year-round.
#531
Scott - do you have the ability to swap maps on the fly (flex fuel)--I believe its been covered within 36 pages I'm not about to go back and search...
#532
No, my car doesn't have it since we went with a non-E85 setup (flex fuel is typically for automatic switching between E85 to non-E85 and back). Switzer does have a R1K or two out there that does have it, however.
#533
I had to run at least 116 leaded race fuel in the past @ $13.00 a gallon to run 30psi before I switched to E85 and I still wouldn't have the spool the E85 provides due to the increase in exhaust gas energy.
With flex fuel I don't have to worry about my maps as the ecu automatically compensates based on ethanol percentage.
Too bad you can't get E85 in VA.
Steve
#534
E85 is awesome in the summer, but I just learned about the winter 70% blend. Startup is hell and all of a sudden am needing to get a new tune for 70%.
What standalone did you go with? Does it not have flex fuel capability?
Steve K.
#535
You also have to factor in the hygroscopic properties that ethanol has, if you get a significant amount of water in your fuel you could have serious damage done. Nothing that we have seen so far, but the chance is there.
#537
That's great info.
It has rarely been mentioned, but certainly worthy of consideration.
#538
It's always awesome to see some guys that are crazy enough to venture into and unexplored territory and keep us posted with the results
enjoy the beast in the best of health good sir, and I wish you miles of smiles with it. Hoping to see an 8 sec pass soon which is VERY close and I am sure is doable with your setup
I am planning to stay stock for a while, and then my goal is not to pass a P800 level kit until more information about the R1k have been gathered.
Switzer cars look amazing, and I have seen the way Neil and other Switzer crew members deal with customers and prospective customers and I really like that about them.
-AJ
-AJ
