AMS ALPHA Throttle body porting service... Great power gains!
Recently we have been talking about some small additions to our part catalog that helped us achieve power beyond that of the ALPHA 12. During testing on our ALPHA 12 car on low boost we saw GREAT improvements in HP and torque across the entire power band. For those looking for a bump in power on any level of GT-R our throttle body porting service is the way to go! We have ported cores on the shelf ready to go for exchange!!!
The AMS Nissan R35 GT-R CNC Ported Throttle Body Service offers solid performance gains and improved throttle response coupled with OEM drivability. Using precision CNC machining, we increase the stock throttle body diameter from 60mm to 63mm providing a 10% increase in airflow area resulting in more horsepower. Your throttle blade shafts are then EDM thinned (Electrical Discharge Machining) to remove excess material. The result is even better flow and less turbulence to provide maximum airflow under wide open throttle. You can expect up to 40HP gains depending on engine configuration from this simple yet very effective service.
Features
http://www.amsperfor...dy-service.html
PM for pricing with core exchange
Eric
Features
- 10% increase in flow area over stock throttle body
- EDM thinned throttle body shaft for better flow and less turbulence
- Improved throttle response
- Up to 40HP gains depending on engine configuration
- 09+ Nissan R35 GT-R
Eric
Last edited by GT3 Chuck; 10-06-2011 at 10:40 AM. Reason: NO PRICING IN OPEN FORUMS!
Doesn't take long at all to remove the tb and I would recommend a retune or to at least have your tuner take a look a log file to make sure no correctional needs to be made.
Eric
Eric
04-28-2022 12:38 AM
Armytrix_F1_Exhaust
07-07-2019 11:31 PM
turbotuner20v
09-11-2015 12:02 PM
08-20-2015 12:17 PM
