Introduction: New to 6speed - S4 and RX7
Hello all, I'm a new member to 6speed and I thought I'd go ahead and make a post introducing myself and my cars to the fellow NorCal members. I own a 2000 Audi S4 for my daily driver and a 1994 Mazda RX7 for my "weekend" car. I plan to pickup a Viper GTS or Viper RT/10 by the end of the year (good move?).
On to the cars!
2000 Stage 3 Audi S4:
KO4's X 2
RS4 Inlet pipes
Ceramic coated exhaust manifolds
Autospeed Fueling kit (60 # injs, 85mm maf)
APR Bipipe
Bosch 044 fuel pump w/ drop in basket
X1 Carbon fiber intake
ER intercoolers
Piggy Pipes
VAST kevlar clutch
OEM Resurfaced Flywheel
RS4 pressure plate
RS4 Engine Mounts
RS4 Tranny Mounts
Snub mount
OEM Febi Control arm and tie rod end kit
Borla Exhaust
710N Div. valves
DMH cutouts pre cat.
ST Coilovers
Drilled and slotted Rotors
Stoptech brake pads
RS4 Grill
Interior:
Podi steering column gauge holder
Vei Boost gauge
Carbon fabric interior trim
Remote switch for DMH cutout activation
![](http://i42.photobucket.com/albums/e338/HardHitter2k4/SAM_0718.jpg)
![](http://i42.photobucket.com/albums/e338/HardHitter2k4/SAM_0715.jpg)
When I had wheels on the car:
![](http://i42.photobucket.com/albums/e338/HardHitter2k4/DSCN1555.jpg)
![](http://i42.photobucket.com/albums/e338/HardHitter2k4/DSCN1546.jpg)
1994 A-spec 500R Mazda RX7
2 Rotor Streetported Atkin seals 2mm Engine - Built by Howard Coleman
Rebuilt 5-speed Transmission
Exedy Stage 3 Clutch/flywheel
Unorthodox Pulley Set
A-Spec 500R T4 Turbo
A-Spec Stainless Manifold
Ceramic Coated Upper and Lower Intake Manifolds
Greddy Type-RS BOV
Tial 44mm Wastegate
RE-A Dual-Tip Cat-Back Exhaust System
A-Spec Down Pipe
A-Spec Mid Pipe
RX-7Store V-Mount Intercooler Kit + Modified KOYO Radiator
Coolingmist Trunk mount water/meth injection kit - Just running water
Apexi PowerFC and Commander
Greddy Throttlebody Elbow
FDNewbie Import Dual Oil Coolers w/ Black Setrab Cores
Supra TT fuel pump
Image Dynamics 725CC primary, 2000CC secondary injectors.
HKS Twin Power
B10EGV Sparkplugs all around
Garfinkle Oilpan Brace
Eibach Pro-Kit Springs
Tokico Illumina 5-way adjustable gas Shocks
Resurfaced Rotors
Hawk HP+ Pads
Greddy Strut Bar
Short shifter
New Miata Battery has been relocated to bin behind passenger seat
A/C Delete
AEM Digital UEGO Air/Fuel Wideband Gauge
AEM Digital Tru Boost Gauge/Boost Controller
AEM Digital Fuel Pressure Gauge
AEM Digital Oil Pressure Gauge
AEM Digital Oil Temperature Gauge
![](http://i42.photobucket.com/albums/e338/HardHitter2k4/DSCN1524.jpg)
![](http://i42.photobucket.com/albums/e338/HardHitter2k4/IMAG0072-1.jpg)
On to the cars!
KO4's X 2
RS4 Inlet pipes
APR Bipipe
ER intercoolers
Piggy Pipes
VAST kevlar clutch
RS4 pressure plate
RS4 Engine Mounts
RS4 Tranny Mounts
Snub mount
Borla Exhaust
710N Div. valves
ST Coilovers
Stoptech brake pads
RS4 Grill
Interior:
Vei Boost gauge
Greddy Type-RS BOV
Tial 44mm Wastegate
A-Spec Down Pipe
A-Spec Mid Pipe
Supra TT fuel pump
HKS Twin Power
Resurfaced Rotors
Hawk HP+ Pads
Greddy Strut Bar
Short shifter
A/C Delete
![](http://i42.photobucket.com/albums/e338/HardHitter2k4/SAM_0730.jpg)
Last edited by GT3 Chuck; 05-22-2011 at 09:09 PM. Reason: Not enough posts or time on the board
Yes, I swung by the SR meet on the 14th hoping to run into some Viper owners to talk more about their owning experience of the car but none were out.
Thanks for the compliments. I'm pretty sure I was checking out your Lambo the majority of the time.
