What's In The Shop Today At Elite Motorsports?
Old 05-21-2011 | 12:15 PM
Kai@ELITEMS's Avatar
Kai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant future
We've been a sponsor on 6Speed for a over a year now.
I'd like to create this thread to give you guys a view and perspective of daily things going on here at Elite Motorsports. I will make this first post a massive one to catch up and will continue to update this thread as the days go by. Enjoy!
B7 RS4 In For Carbon Cleaning Service
996 GT2 For Oil + Filter Change
R35 Nissan GTR In For Cobb Tune, Meisterschaft Exhaust, Intake, AP Midpipe (Sorry about the mess in the shop, must've been alot of things going on that day!)
Another B7 RS4 On The Lift For Carbon Cleaning
Custom Stage 3 8 Puck Clutch Masters Clutch Built To Our Specs For 997T Project
Another RS4 for CB Service (We've done over 20 of them!)
Nogaro vs. Sprint Blue
B7 S4 In For Misfire Issues
MKI TT
Another RS4 For CB Clean []
Parking Lot
Cayenne On The Lift
B7 RS4 ECU Flash
R8 V8 4.2 In For Some Goodies []
Old School C4 S4
997T Short Shifter Install
Stage 3 on B5 S4
Oil Leak Diagnosis On 996T Porsche
Another RS4 In For Carbon Clean Shop Is Full
Motor Pull On 996T Porsche
Mini Cooper S In For Suspension Mods
Old 05-21-2011 | 12:16 PM
2011 BMW M3 Exhaust Install
B8 A4 Springs Install
Customers GTI Up Front
APR GT28 Kit On B5 A4
Another RS4 []
B6 S4 For Coilovers
Winner Of Cliffs Of Insanity Oil Change RS4
R8 Back For Service
800HP Vette Sleeping Inside
A5 In For Service
RS4 Back For 2nd Carbon Cleaning
B5 S4 Fueling Kit Install
Snow [:/]
MK5 GTI In For Boost Problems
R32 For O2 Sensor
Stage 2 Reflash On MK6 GTI
Timing Belt on 2.0T A4 and Valve Cover Gaskets
Podi Boost Gauge On B5 S4
Xenon Headlight Swap & Coding On B8 A4
K04 Rebuild On 337 GTI
KW Install on B7 S4
R8 Again
B6 S4 Avant On The Lift
B8 A4 On The Lift For Suspension Upgrades
Flashing a 2011 A3 ECU W/ APR Software
Turbo Swap On B5 S4
B8 S4's Waiting For Upgraded ECU's
Grille Swap on B8 S4
996 Turbo Porsche MAF Swap
Intake & Scoop Install On 2011 M3
2007 911 Turbo In For Many Upgrades
Quick Update!
More customers taking advantage of APR's Spring Sale! Fully loaded ECU tunes are $599!
Two White B6 Passats In For Some Service and General Maintenance
Customer B7 A4, We Mounted His Summer Wheels On The Car For Him
B8 S4 In For APR Exhaust Install
MK5 GTI Axle Replacement and APR ECU Flash
A4 Convertible In For Oil Pump Replacement & Pressure Switch, New CTS and Coilpacks
Old 05-21-2011 | 12:17 PM
Porsche Cayenne, Coolant Pipes Replacement Under Intake Manifold
B6 S4 Auxilary Radiator Swap
Slammed MK5 GTI (Had fun getting this one on the lift). Cam Follower Swap & Oil/Filter Change
E46 M3 In For Some Minor Transmission Issues
Stage 2 B7 A4, Boost Problems Still Working On This On This One, It's A Bit Tricky...
MK6 GTI APR Catback Install & Stage 2 APR/Carbonio Intake
S6 In For CV Joint Replacement
Customers B5 S4 Avant Getting Looked Over On The Lift, Replaced Wheel Bearings & Rear Differential Seals Before It's Cross Country Trek Back To California, Also 3 ECU Upgrades, One Being a 2011 B8 A4.
Cactus B5 S4 Came In To Adjust Coilover Suspension
Quick update
Audi S5 Carbon Buildup
Ordinary Day
These (One B6 The Other B7) Cabriolets Came In For Oil Service, Timing Belt Service, As Well As A Tune Up.
Audi A3 Stage 2 Reflash and APR Downpipe Install
2003 Porsche Carrera 4 S In For A Small Diagnosis, Turns Out It Needed a MAF.
Old 05-21-2011 | 12:18 PM
Another Quick Update
Customers Clean MK6 GTI Came By For A Visit
C6 A6 With S8 Wheels And Suspension Waiting To Go Inside The Shop For Some Work
Customers B8 A4 Gave It It's New Look, Suspension and 19" S4 Wheels.
B7 A4 In For LED Taillight Swap & Oil/Filter Service
DJ Carl's Go Fast Box Has Arrived, Stay Tuned.
997 Carrera ECU Tuning
DJ Carl, GT28 Stage 3 Project Complete
Ignore temporary air filter, Carbonio setup is on the way.
Car runs great!
Minor Update
This Nice A6 Came By For Some Diagnosis, Ended Up Doing A Major Service,New Coils,Brake Fluid Flush,Replaced Inner Upper Control Arm Bushings,New Stabilizer Links,Replaced Valve Cover Gaskets,New Evap Valve,Transmission Fluid & Filter & Gasket Change,Flush Rear Differential Fluid, & Installed Milltek Catback Exhaust (Sounds Great!)
Full House C5 A6 Getting New Suspension & Major Service, B7 A4 Stage 3 Big Turbo GT28 Complete Waiting For Pickup, C5 S6 In For Brake Service, C6 A6 Waiting To Get Diagnosed
Sample Air Freshener
Mk6 GTI Up On The Lift For Turboback APR Exhaust & Stage 2 + Reflash
B7 RS4 Upgraded 034 Transmission Mount Install
Valve Cover Gaskets & Driver Side Auxilary Radiator Replacement On B6 S4
Old 05-23-2011 | 07:19 AM
B7 RS4 Transmission & Rear Differential Fluid Flush
08 Gallardo Stopped By For E-Gear Issues
Doing A Full Timing Belt Service & Spec Stage 2 Clutch On This GTI 1.8T
Mean Looking RS4 In For Intake Spacers, Clutch, Flywheel Upgrade As Well As A Carbon Cleaning. Stay Tuned For After Carbon Clean Dyno #'s. The Way It Sits Now It Put Down 296whp.
Pictures Of The Carbon On The RS4, (More Pics Soon!)
B8 S4 On The Dyno Full Exhaust, APR 93 Octane ECU Tune, Intake...376whp. Next mod, HFC(Maybe Testpipe) & PULLEY!
Old 05-23-2011 | 03:58 PM
Oxygen's Avatar
Oxygen is infamous around these parts
Great work guys!
Old 05-28-2011 | 08:03 PM
Laser Red B5 S4 Up On The Lift Swapping In Testpipes & New EGT Sensors
More RS4's!
500+HP Sleeper A6 In For Some Maintenance
Here is AZ Member Scotty607's RS4 Back On The Dyno After Carbon Clean & APR ECU Upgrade Nice Gains!
http://www.youtube.com/watch?v=k1lSlvOTR4I&feature=channel_video_title
Old 06-04-2011 | 08:36 PM
2.7 Allroad Full Timing Belt & Major Service. Timing Belt, Tensioner, Tensioner ,Roller, Idler Pulley, Water Pump & Gasket, Thermostat & O-Ring, Serpentine/Accessory Belt, Coolant Flush, Cabin, Air, Fuel, Oil Filter, New Plugs, Fresh Fluids.
This A8L Came By For Some Maintenance, (We Do That Here Too!)
Clean B5 S4, Flashed The ECU W/ ASP Stage 1 Software, Fixed Some Other Minor Problems And Sent It On It's Way!
Stage 3 B5 A4 On The Lift For Oil Pan, Silver A4 Waiting For Pickup, TT In For Diagnosis.
Old 06-09-2011 | 02:54 PM
RS4 In For STASIS SL Coilovers & Spacers
B8 S4 with APR ECU/AWE Intake Up On The Lift Getting RSC APR Exhaust Put On
Silver Passat, Timing Belt Job Done By Customer Unfortunately Gone Wrong Need To Get That Up & Running Correctly, Black B7 A4 Most Likely Needs A New Cam/Head.
Old 06-16-2011 | 11:44 AM
Porsche Cayenne S Ready For Pick Up, Coolant Pipes Under IM Complete.
Another Porsche Cayenne In For Brake Service
More RS4's!
B7 A4 w/ K04 Kit Reflashing ECU
Slammed MK5 GTi In For Some Work, Possible Camshaft Problems..
Who Want's Some Pens!
Passat Motor Ready To Go Back In
B8 A4 Grille Swap
Old 06-29-2011 | 11:49 AM
2011 GTI "R" Edition VERY RARE Inside Getting ECU Upgrade
V10 S6 In For Oil Service & APR, LLC. ECU Flash!
A8L In For Misfiring Issues & Navigation Deck Screen Problems
6 Speed Allroad In For Some Work, Don't See These Quite Often..
First Step: Put APR, LLC. B8 S4 3.0TFSI Pulley In Toaster
R32 Stopped By For CEL
B7 A4 Getting JHMotorsports Inc. Light Weight Rotors & 6 Piston Cayenne Big Brake Kit Upgrade
2011 Porsche Panamera S In For It's First Oil Change Service
Old 07-23-2011 | 12:58 PM
Haven't updated in a week or so, here's some of the latest things going on!
Full House
B7 A4 2.0 Turbo Head Rebuild
Very Clean MK6 GTI W/ Golf R Front End Taking Advantage Of APR, LLC. ECU Upgrade Sale! $599 For 4 Programs & All Options!
Bullrun Rally Vegas to Miami Launches Tonight 4-6PM, If You're In Vegas Check It Out On Freemont Street & Look Out For Team RS6! Elite Motorsports 034Motorsport EPL -: European Performance Labs :- PetrolWerks
B8 S4 Stabilizer Alu-Kruez Install
Rear Axle Replacement On B5 A4
Waterfest Prep On The Shop B8 S4. Be Sure The Stop By Our Booth On Saturday & Sunday!
Back In Action Full Force At The Shop After Waterfest: The VW & Audi Car Show and Motorsport Event 17! Had An Epic Turnout, Ran Out Of The Thousands Of Cards/Goodies We Were Giving Away. Thank You To Everyone That Stopped By The Booth & For The Support, We Appreciate It Very Much!
Porsche Cayenne S Brake Service
B7 A4 ER Stealth FMIC Install, Waiting On Pipes To Arrive
B7 S4 In For Full Front Control Arm Replacement With 034Motorsport Adjustable Uppers
S8 Getting Some Maintenance Done
2011 Audi B8 A4 Full APR, LLC. Downpipe & Catback Exhaust Install
TSI Intake On MK6 GTI
Nice Looking M Coupe Stopped By
Old 08-04-2011 | 02:22 PM
MK4 GTI VR6 In For Full Brakes, ECU, Intake, Control Arms, Axle Boot, Full Suspension Upgrade With Sway Bars
BMW 330i In For Some Work & It's A 6 Speed!
My B5 S4 @ Englishtown
B6 S4 In For Maintenance Before Driving To Colorado
B7 A4 In For Oil Change & Filter
Old 08-15-2011 | 09:08 AM
Another weekly update!
A8 L Getting New Goodies, MMI, New Switches, New Windshield Wiper Motor & Linkage/Transmission, Suspension Compressor etc.
2009 VW GTI TSI Getting H&R Coilover Suspension Upgrade
This Is How It's Done.Thanks To Chris Mallari For The Awesome Picture! Elite Motorsports B5 S4 Launch.
Stage 3 B5 S4 Up For Transmission/Rear Differential Flush, Oil & Filter Change & Alignment
APR, LLC. Stage 3 B6 A4 Ready For Pick Up After We Installed A Clutch Masters FX400 6 Puck Stage 4 Clutch & Light Weight Steel Flywheel. Same Setup We've Abused On The Track Numerous Times With The B5 S4.
MK4 GTI In For Full Timing Belt Service Also An Oil/Filter Change As Well
997 Porsche Carrera S Up In the Air For Oil & Filter Service
Quick Reply: What's In The Shop Today At Elite Motorsports?
