Final Photoshoot of Veilside Fortune Widebody with New Stereo Installed NO 56K
#32
you are crazy!! the only thing that i can say is wow! how is the gt street comming along??
#34
GT Street is coming along. So many little parts I had to source from Porsche Germany. Some of the ducting for the intercoolers is different from the 996 tt and 997. Also I bought some new GT2 intercoolers so getting everything to match up has been a little bit of a hassle. Should have pictures posted tommorrow of the body painted.
#36
How much do you want for the RX7 and where will it be listed at for sale? Please send me all spec's on this ride because if its at the right price I will buy it.
#37
Mod List
Exterior
- Repainted BASF Glasurit Lamborghini OEM Pearl Yellow Two Tone Black
- Veilside Fortune Widebody Kit
- Veilside Fortune Hood
- Veilside Fortune Front Bumper
- Veilside Fortune Carbon Fiber Headlight Buckets
- Veilside Fortune Rear Bumper
- Veilside Fortune Side Mirrors
- Veilside Fortune Rear Wing
- Veilside Fortune Carbon Fiber Front Lip
- Veilside Maijisty Crystal Emblems
- Vertical Doors Custom Lambo Door Kit
- Xenon Vision Custom 12000K HID Kit
- 99 Spec JDM taillights
- Carbon Innovation Carbon Fiber Door Handles
Interior
- Carbon Innovation Carbon Fiber Center Console
- Carbon Innovation Carbon Fiber Speed Cluster
- Carbon Innovation Carbon Fiber AC Panel
- Carbon Innovation Carbon Fiber Shifer Console
- Suede A Pillar
- Suede Headliner
- Suede Rear Hatch and Trunk Area
- Suede Shiftboot
- Suede Handbrake boot
- Cusco 8pt. roll cage
- Bride Vios III Seats
- Bride RX7 Seat Rails
- Sparco 6pt Racing Harness
- Sparco Suede Ring Steering Wheel
- NRG Quick Release Steering Wheel Kit
- Autometer Nexus Control Module
- Autometer Nexus Air/Fuel Wideband Gauge
- Autometer Nexus Fuel Pressure Gauge
- Autometer Nexus Boost Gauage
- Autometer Nexus Oil Temp Gauge
- Autometer EGT Gauge
- Autometer Water Temp Gauge
- Autometer Oil Pressure Gauge
Engine
- street port engine (Redline Engineering) 11k miles
- new 2 mm seals
- new rotor housings
- cryogenically treated engine seals
- lightened, clipped, and balanced rotors (Racing Beat)
- intake ports polished
- new pinned housings and other special machining for sand-rail motor (Redline Engineering)
Turbo
- HKS T04E single kit
- Greddy Front Mount Intercooler
- HKS SSBOV
- APEXi AVC-R Boost controller
- HKS air filter
Cooling
- Koyo Aluminum radiator
- Earl's 32 row oil cooler
- Unorthodox pulley set
Transmission/Drivetrain
- KAAZ 2-way LSD
- MazdaSpeed Power-Plant-Frame RARE
- B&M Short Shifter
- ACT street/strip clutch w/ extreme pressure plate
- Racing Beat 11 lb alum. flywheel
Fuel Management
- PowerFC computer tuned by XS Engineering w/ commander
- 660 cc pri, 1200 cc sec RC injectors (flowed and blueprinted)
- SX fuel pressure regulator
- Denso fuel pump
- Magnecor plug wires
- HKS iridium spark plugs
- B&M Newvolt Ignition Amp
- HKS Grounding System
Exhaust
- ceramic coated exhaust manifold,
- ceramic coated exhaust housing of turbo
- ceramic coated down-pipe
- HKS Carbon Fiber Titanium Exhaust
Suspension/Brakes/Wheels
- Rotora 6 Piston 14" Front Kit
- Rotora 4 Piston 13” Rear Kit
- New Mazda 929 brake master cylinder
- CWC sway-bar mounts
- Racing Beat front and rear sway bars
- Cusco front strut bar
- Tein Flex Coilovers
- Tein EDFC
In Car Electronics
- Pioneer Avic D1 Navigation Head Unit
- Custom Fiberglass Amp Rack
- Custom Fiberglass Sub Enclosure
- 2 Rockford Fosgate T152S POWER series 100 Watt RMS, 5.25” component system
- 2 Rockford Fosgate 2001bd POWER series AMP
- 1 Rockford Fosgate T18004 POWER series AMP
- 4 Rockford Fosgate T110D2 POWER series 10” woofer
- Lightning Audio AMP and Power Wires
- Optima Yellow Top Battery
- 2.5” Rear View Monitor
Exterior
Interior
- Suede A Pillar
- Suede Headliner
- Suede Shiftboot
Engine
- new 2 mm seals
Turbo
- HKS SSBOV
- HKS air filter
Cooling
- KAAZ 2-way LSD
- B&M Short Shifter
Fuel Management
- Denso fuel pump
Exhaust
- Tein EDFC
In Car Electronics
#44
car sold for asking price. It is now on the east coast. Thanks everyone for their comments. I had a great time building the car. Now onto the new project which is about a month from the finish line.
