post pics of your evo
#125
New pics.
New mod list......
2004 Mitsubishi Evolution 8
Chassis has 36k on it. Mods have less than 2k.
Engine:
Fully Built 2.3L Stroker
Fresh Core
Fully Sleeved Block by Darton
Crower 4350 Pro Series Billet Rods
Crower 4340 billet steel crankshaft 102mm stroke
ARP Main Bolts
ARP Rod Bolts
Buschur Racing Stage 3+ race head
Fresh Core
Ferrea dual stainless steel valve springs
Ferrea titanium retainers, locators, and locks
New Valve Seals
Custom BR Bronze valve guides
Supertech Nitride Coated Intake Valves
Supertech Nitride Coated Exhaust Valves
Stainless O-ring around each combustion chamber
Complete port & polish
New Bronze Valve Guides
ARP L19 Head Studs
Fluidampr Harmonic Balancer
Virtual Works Racing Aluminum Intake Manifold
4 inch Virtual Works Intake
AMS front and side engine mounts
ARC Radiator Cooling Panel
Black Powdercoated Valve Covers
Billet Timing Tensioner
818 Billet Power Steering Cap
Sparktech COP Pro CDI-12
HKS 280/280 Cams
HKS Adjustable Cam Gears
Fuel:
AMS Fuel Rail
Fuel Lab Fuel Pressure Regulator Black
Precision 1200cc Injectors
Buschur Racing Dual Fuel Pumps
Exhaust:
Greddy Ti-C Downpipe back Exhaust System
Virtual Works Racing Stainless Downpipe
Turbo + Cooling:
Virtual Works Racing Coated T4 Race Header
Tial Polished 44mm Wastegate
Precision 6262 Dual Ball Bearing Billet Wheel Turbo
DEI Titanium Turbo Heat Shield
Virtual Works FMIC
Virtual Works Custom Stainless 3.5 inch intercooler piping
Tial 50mm Q BOV
Virtual Works Stainless Pipe Strapping
Virtual Works Upper Radiator Hard Pipe
Virtual Works Lower Radiator Hard Pipe
Fluidyne Aluminum Radiator
Mishimoto Race Thermostat
Virtual Works Custom Aluminum Overflow Can
Virtual Works Custom Aluminum Breather Can
Virtual Works AN Fitting/Braided Hose Breather Kit
Powdercoated Radiator Tie Downs
ARC 1.5 bar radiator cap
Spal 10 Inch Low Profile Electric Fan
AMS 25 Row Oil Cooler
Spal 5.2 inch Oil Cooler Fan
Transmission/Drivetrain:
Shepherd Racing Stage 1
New throwout bearing
New clutch fork, pin and return springs
New speedometer gear and sensor
New slave cylinder and line
REM ISF process (sliders only)
REM ISF process (gearset assembly)
Double synchro 5th gear option
Shepherd Racing Stage 3 Transfer Case
Quaife LSD front differential
8mm to 10mm bolt upgrade
New seals and o-rings
Reshimming
Neodymium magnet
REM ISF Process
New ring and pinion with bearings
Shepherd Racing Rear Differential
Cusco LSD
REM ISF Process Ring + Pinion
Buschur Racing Rear Moustache Bar
Buschur Racing Rear Billet Side Diff Mounts
Drive Shaft Shop Level 5 900HP Rear Axle/Hub Kit
Exedy Wasabi Triple Ceramic Clutch
Hyper Multi Plate
AWD Motorsports Aluminum Driveshaft
Buschur Racing Driveshaft Loop
B&M Short Shifter
ARC Titanium Shift ****
Kartboy Shifter Base and Shifter Bushings
Suspension:
Tien Monoflex Coilovers
ARC Front Strut Tower Bar
Cusco Rear Strut Brace
Cusco Front + Rear Sway Bars
Wheels:
Volk Racing RE30 18x9 (black gloss powdercoated)
Volk Carbon Center Caps
Advan Neova AD08 265/35/18
Volk Racing Duralumin Lugnuts (black)
Brakes:
Endless Racing 6 Piston Race Front Brake Kit
Endless Racing 4 Piston Race Rear Brake Kit
Endless Stainless Covered Teflon Swivel Brake Lines
Endless Brake Pads
Zeal Slotted Rotors
Interior:
Rexpeed Carbon Fiber Dash
Custom Carbon Fiber Shifter Console
Custom Carbon Fiber Glove Box
Rexpeed Carbon Steering Wheel Gauge Pod
Rexpeed Carbon A-Pillars
Ralliart Aluminum Door Sills
Tyrant Carbon Armrest
EVO SE Leather/Suede Seats
Black Suede Wrapped Evo 8 Steering Wheel
Mitsubishi JDM Double Din
Orbital HVAC conversion kit
Electronics:
Kenwood DNX8120 indash Nav/DVD
Rockford Fosgate Dual Amps
Boston Acoustics Front Mids
Boston Acoustics Front Tweeters
Boston Acoustics Rear Speakers
Boston Acoustics 10 inch Subs w/custom Fiberglass Enclosure
Greddy EGT + Oil Temp gauges
AEM Boost + AFR Gauges
AEM Stand Alone EMS
AEM 5 Bar Map Sensor
Exterior:
Chargespeed Vented Carbon Hood
Chargespeed 20mm Fenders
Chargespeed Carbon Vortex Generator
Chargespeed Type 1 sideskirts
Chargespeed Type 1 front bumper
Chargespeed Type 1 rear bumper
Chargespeed Rear Carbon fiber diffuser
Rexpeed Carbon Fiber J-Panels
Rexpeed Winglet
Mitsubishi Carbon Fiber Evolution VIII Truck Emblem
Hyboost Performance Edged + Tinted headlights
Hyboost Performance Tinted taillights
Hyboost Performance Smoked Side Markers
Dafarmer LED License Plate Light
Rexpeed Carbon Mirror Covers
Custom Apex Silver w/ slight blue pearl in paint
Evo XI Wing
New mod list......
Engine:
Fresh Core
ARP Main Bolts
ARP Rod Bolts
Fresh Core
New Valve Seals
ARP L19 Head Studs
HKS 280/280 Cams
Fuel:
AMS Fuel Rail
Exhaust:
Turbo + Cooling:
Virtual Works FMIC
Tial 50mm Q BOV
Reshimming
Neodymium magnet
REM ISF Process
Cusco LSD
Hyper Multi Plate
B&M Short Shifter
Suspension:
Wheels:
Brakes:
Endless Brake Pads
Zeal Slotted Rotors
Interior:
Electronics:
AEM Stand Alone EMS
Exterior:
Rexpeed Winglet
Evo XI Wing
#132
